MaaXBoard Hardware Design MaaxBoard-RT: now both PHYs are working - for you
  • Subscribers 340 subscribers
  • Views 535 views
  • web browser
  • SDK example
  • Maaxboard RT
  • ETH PHY
tjaekel
tjaekel over 2 years ago
I have both PHYs working (the 1G PHY is a different one as on SDK and eval board, it needs modification when you start with SDK examples).
You can connect with Web Browser to one or both, even in parallel.
Each PHY has also a name you can use in web browser (if you do not know the IP address, mDNS is running):
"maaxboard" vs. "maaxboardg"
GitHub - tjaekel/MaaXBoard-RT_SPIder: MaaXBoard-RT SPIder framework
BTW:
WiFi is not enabled yet (I have not yet merged the code for it).
  • tjaekel
    "maaxboard/" vs. "maaxboardg/"
  • tjaekel
    TFTP is up an running:
    transfer files from/to USB memory stick via network and TFTP
    You have to specify files on MaaXBoard file system as: "1:/finame" (the 1:/ as drive letter, also on TFTP command).
