MaaXBoard Hardware Design How to Interface an Ultrasonic Sensor (HC-SR04) with MaaxBoard OSM93 Using Cortex-M33?
  • Subscribers 358 subscribers
  • Views 173 views
Manju123
Manju123 over 1 year ago
Hello Community,
I am working on a project using the MaaxBoard OSM93 (i.MX93, Cortex-M33 core), and I need help interfacing the HC-SR04 ultrasonic sensor for distance measurement.
I would like to implement this using the Input Capture (IC) feature to accurately measure the ECHO pulse width.
Could you please help with the following points:
  1. Pin Selection & Pinmux Configuration:
    • Which GPIO pin or TPM input channel is suitable for the ECHO signal (input capture)?
    • How do I configure the pinmux to enable input capture on the chosen pin?
    • How should I update pinmux.c and app.h files to reflect the configuration?
  2. Trigger Signal Setup:
    • For the TRIG pin (output), what’s the correct GPIO configuration and setup in the pinmux tool?
  3. Driver Usage:
    • Is there an available Input Capture driver or example code for i.MX93/Cortex-M33 using MCUXpresso SDK?
  4. Application Code Integration:
    • Any guidance or example for writing an ISR or polling logic to calculate distance based on pulse width?
Any working examples, configuration files, or documentation links related to using input capture with HC-SR04 on the OSM93 platform would be very helpful.
Thank you!
