MicroZed Hardware Design Does Xilinx Platform cable works for Microzed Jtag?
  • Subscribers 359 subscribers
  • Views 339 views
I'm trying to connect JTAG in microzed using Xilinx Platform cable[1], is it valid connection?
When I try to install drivers for these in SDK/2015.3/data/xicom/cable_drivers/lin64/install_script/install_drivers
It is getting installed but, I'm unable to see Status LED glow and I couldn't find /dev/windrvr6
Any help?
[1] http://www.xilinx.com/products/boards-and-kits/hw-usb-ii-g.html
  • drozwood90
    0 drozwood90 over 10 years ago
    Hi there,
    Nothing that I see leads me to think it works with Vivado.  Zynq officially only runs with Vivado.  From what I can see on the Xilinx forums, it appears that officially this does not even work under Windows 7.
    It is highly suggested that you update to a JTAG-HS3 to perform Zynq work.
    [http://avnetexpress.avnet.com/1/1/11833501-digilent-inc-jtag-hs3-programming-cable-xilinx-fpgas-210-299p-kit.html ]
    I would also suggest you post a question about this on the Xilinx Support Forums.  If you get an answer, can you please post a link back to that thread?
    https://forums.xilinx.com/
    --Dan
  • drozwood90
    Hi there,
    I was speaking with a colleague about this.  He thinks that it will work
    He provided me a link to the datasheet:
    http://www.xilinx.com/support/documentation/data_sheets/ds593.pdf
    On the first page it does state that it is compatible with Vivado.
    --Dan
