Have just started with a MicroZed board Evaluation. Unit boots fine from QSPI, and I have run through startup doc with no issues. I can mount, read/write to the SD, but when I try to power-on boot from the SD after copying the image files to the SD, in the boot-up info I get:
"Error: Timeout waiting for FPGA to config.
fpga - loadable FPGA image support..."
...then lists the usage for "fpga" call.
Any thoughts?
Thanks in advance.
