    • Avnet Boards Community
MicroZed Hardware Design Zynq Release images work for Microzed board?
  • Subscribers 309 subscribers
  • Views 423 views
shyamthella
shyamthella over 8 years ago
Hi All,
The release images which Xilinx provides, will that boot for microzed board also? or only Zed board?
I have a microzed board in which I am using Avnet pulsar linux distribution. I am not able to add any changes to its kernel as it is Yocto distribution.
Please tell me where can I use a linux source to add changes and boot it properly like how we do for a Zynq ZC706/702 board..
Shyam
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello shyamthella,
    When you say released images are you refering to the petalinux release that they offer for the Zedboard? if yes, then to answer the question, no it will not work with your MicroZed.
    However, if your goal is to use Petalinux on your MicroZed, then please download the Petalinux Board Support Package of your choosing and follow the directions that come with it. http://zedboard.org/support/design/1519/10
    --Josh
  • shyamthella
    0 shyamthella over 8 years ago in reply to jafoste4
    Hi Foster,
    My requirement is to have a kernel source which boots on microzed so that I will add a module, built it with that kernel version & insert in in microzed.
    The module does nothing except creating a devnod and read write operations which I use to read some peripheral.
    As per your reply I found some open source linux images in following link. I found that the kernel version is 3.17 and read me says this uses 14.4 Zynq releases.
    Now my question is where can I get an open source kernel code which I can compile and boot on microzed. DOn't say pulsar linux because that is Yocto distribution and I am not able to modify its kernel source as it fetches from remote repo every time.
  • jafoste4
    Hello shyamthella,
    You could try going through the Implementing Linux on the ZynqRegistered-7000 All Programmable SoC SpeedWay Training
    http://zedboard.org/course/implementing-linux-zynq%C2%AE-7000-all-programmable-soc-ise-142
    The only disadvantage of that training is that is was done using ISE 14.2 and not Vivado.
    --Josh
