    Members
    • Experts & Guidance
    • Avnet Boards Community
    • Or choose another store...
MicroZed Hardware Design Chipscope with Microzed USB-JTAG
Avnet Boards Forums requires membership for participation - click to join
  • Subscribers 176 subscribers
  • Views 177 views
ghalady
ghalady over 9 years ago
Was wondering if the PL logic can be debugged using CHipScope and USB JTAG through the USB cable provided with the Kit
  • bhfletcher
    0 bhfletcher over 9 years ago
    Since there is no USB-JTAG circuitry built onto the MicroZed, the answer is no. The simple microUSB cable provided with the kit is only good for UART communications.
    An external USB-JTAG cable like the HS1, HS2, or Platform Cable USB give you the JTAG capability for configuration and debug, including ChipScope or Vivado Analyzer.
    Bryan
  • ghalady
    0 ghalady over 9 years ago in reply to bhfletcher
    Thanks Bryan, Was trying to get answers from Tech support. APpreciate the inputs.
    Girish
    0 Former Member over 9 years ago
    Hi Girish,
    If you are super-deperate to see what is going on and you don't have a JTAG cable then have a look at Cheapscope (http://hamsterworks.co.nz/mediawiki/index.php/CheapScope).
    It has none of the features of ChipScope, but I have successfully used it to debug an SDRAM controller on a Spartan 6 connected to a Raspberry Pi.
    It might need a bit of work - maybe replace the RS232 interface with with something else.
    Having this up and running on the MicroZed, including the terminal program, would be a pretty cool way to troubleshoot designs in situ.
    Mike
An Avnet Company © 2023 Premier Farnell Limited. All Rights Reserved.
