    Members
    • Experts & Guidance
    • Avnet Boards Community
    • Or choose another store...
MicroZed Hardware Design JTAG
Avnet Boards Forums requires membership for participation - click to join
  • Subscribers 176 subscribers
  • Views 173 views
JTAG
lgmlgm
lgmlgm over 6 years ago
Hello  every body
I have a MicroZet board from avnet.
I want to run the program "hello world" (tuto 2)
I have succefully generated the .cache, .hw, .ip_user_files,. Runs, .sdk, .sim, .srcs and .xpr  files (of the tuto 1).
But I'm stuck in Chapter 4: Run on hardware point 9, when I click on Program (Figure 22), I have the following error:
Programm FPGA failed
Reason: Could not find FPGA device on board for 'Local' connection.
I have installed all the driver (USB to UART, Platform cable USB)
Thanks in advance
  • linch
    0 linch over 6 years ago
    Dear All,
    I had the same problem. I saw the ZYNQ FPGA was detected in hardware manager of Vivado for few seconds only when I connected JTAG cable to my MicroZed for first time. Then it cannot be detected anymore. I checked all voltages. They are OK.
    My ZedBoard is BD-Z7MB-7Z020-G REV F-07. (SIG 1433228 MEXICO)
    Thanks very much.
  • jafoste4
    0 jafoste4 over 6 years ago
    Hi lgmlgm,
    I am thinking your issues lies with the Platform cable you are using. We here at Avnet specifically support the Digilent HS3 cable with our SOMs and Development Boards. So my suggestion would be for you to purchase a Digilent HS3 cable https://products.avnet.com/parts/components/2004746-digilent-jtag-hs3-programming-cable-xilinx-fpgas-jtag-hs3-high-speed-cable.html
    If you still wish to use the Programming cable, I am going to suggest that you ask your question over at the Xilinx forum.
    Hi linch,
    Are you using the Xilinx Platform cable or a cable besides the Digilent JTAG HS2/HS3 cable? If so please refer to the response above.
    Josh
  • lgmlgm
    0 lgmlgm over 6 years ago in reply to jafoste4
    hi JFoster,
    Yes, you was right. The problem was the platform cable. I was using platform cable USB of  Xilinx. Now i am using Digilent JTAG HS3 cable and it works.
    Thx you so much
An Avnet Company © 2023 Premier Farnell Limited. All Rights Reserved.
