MicroZed Hardware Design petalinux-config  error for creating petalinux project
  • Subscribers 336 subscribers
  • Views 2034 views
gsm2019
gsm2019 over 6 years ago
petalinux-config
WARNING: Your PetaLinux project was last modified by PetaLinux SDK version "2018.2",
WARNING: however, you are using PetaLinux SDK version "2019.1".
Please input "y" to continue. Otherwise it will exit![n]y
[INFO] generating Kconfig for project
[INFO] menuconfig project
configuration written to /home/gsm/Xilinx/petalinux/mz7020_fmccc_2018_2/project-spec/configs/config
*** End of the configuration.
*** Execute 'make' to start the build or try 'make help'.
[INFO] sourcing bitbake
[INFO] generating plnxtool conf
[INFO] generating meta-plnx-generated layer
[INFO] generating user layers
[INFO] generating machine configuration
environment: line 1557: [: ==: unary operator expected
environment: line 1589: [: ==: unary operator expected
[INFO] generating bbappends for project . This may take time !
environment: line 1382: [: ==: unary operator expected
environment: line 1384: [: ==: unary operator expected
environment: line 1386: [: ==: unary operator expected
ERROR: Unable to start bitbake server
ERROR: Server log for this session (/home/gsm/Xilinx/petalinux/mz7020_fmccc_2018_2/build/bitbake-cookerdaemon.log):
ERROR: ParseError at /home/gsm/Xilinx/petalinux/mz7020_fmccc_2018_2/project-spec/meta-plnx-generated/conf/machine/plnx-zynq7.conf:1: Could not include required file conf/machine/include/tune-.inc
[INFO] generating u-boot configuration files
[INFO] generating kernel configuration files
[INFO] generating kconfig for Rootfs
Traceback (most recent call last):
  File "rootfs_config.py", line 316, in <module>
    parse_args(sys.argv[1:])
  File "rootfs_config.py", line 290, in parse_args
    extract_packages_dot(packages_user)
  File "rootfs_config.py", line 257, in extract_packages_dot
    with open(packages_dot,'r') as fp:
IOError: [Errno 2] No such file or directory: '/home/gsm/Xilinx/petalinux/mz7020_fmccc_2018_2/project-spec/meta-user/recipes-core/images/petalinux-image-full.bbappend'
ERROR: Failed to generate rootfs /home/gsm/Xilinx/petalinux/mz7020_fmccc_2018_2/build/misc/rootfs_config/Kconfig.user
ERROR: Failed to config project.
  • jwillia-ray
    jwillia-ray over 6 years ago +1
    I was having the same problem. Downgrading Petalinux to 2018.3 appears to have fixed the issue.
  • jwillia-ray
