Mini-ITX Hardware Design Voltage level at FMC Pins
  • Subscribers 339 subscribers
  • Views 417 views
Former Member over 9 years ago
Hi everyone,
I'm currently trying to get a 3.3V output level at some of the FMC pins.
Using a scope I figured out, that also in the unloaded case I only get ~2.5V. My configuration for single ended signals in the xdc file is th following:
set_property PACKAGE_PIN AC16 [get_ports test]
set_property IOSTANDARD LVCMOS33 [get_ports test]
#set_property DRIVE 16 [get_ports test]
set_property PULLUP true [get_ports test]
Are there differences in the max ouput voltage between the different banks?
Do I need to do something more of implementation/configuration/... to ensure the ability of 3.3V output?
Thanks for any hints
Kris
    0 Former Member over 9 years ago
    I solved my problem:
    There is the jumper JP7 used to select the voltage supply of the FMC connector. Further details could be found in the "Board-User-Guide" section 2.15.1 'FMC VADJ'
