    • Avnet Boards Community
MiniZed Hardware Design Error programming MiniZed FLASH in Tutorial #4
  • Subscribers 310 subscribers
  • Views 1594 views
jdehaven
jdehaven over 7 years ago
I have an issue where I am in the 04_MiniZed_FSBL_Boot_2017_01_01.pdf lab, and at the point of Programming the Flash memory.  I keep coming to the “Program QSPI Flash Memory” step and it fails with the following message:
****** Xilinx Program Flash
****** Program Flash v2017.4 (64-bit)
  **** SW Build 2086221 on Fri Dec 15 20:55:39 MST 2017
    ** Copyright 1986-2017 Xilinx, Inc. All Rights Reserved.
Connecting to hw_server @ TCP:127.0.0.1:3121
Connected to hw_server @ TCP:127.0.0.1:3121
Available targets and devices:
Target 0 : jsn-MiniZed V1-1234-oj1A
       Device 0: jsn-MiniZed V1-1234-oj1A-4ba00477-0
Retrieving Flash info...
Initialization done, programming the memory
BOOT_MODE REG = 0x00000000
Problem in Initializing Hardware
Flash programming initialization failed.
ERROR: Flash Operation Failed
Labs 1-3 work fine.  Have you seen this before and is there something that the instructions may lack that we are supposed to do?
  • jafoste4
    0 jafoste4 over 7 years ago
    Hello Jdehaven,
    Please confirm that when programing your board your boot mode is set to J(for Jtag).
    Also please take a look at this post http://zedboard.org/content/error-04minizedfsblboot2017101 and confirm whether or not your issue is similar.
    Seeing as that tutorial was initailly created using Vivado 2017.1 would you be willing to revert back to Vivado 2017.1 and try the tutorial once again to see if your issue is tool version related?
    I will peronally try going through the tutorials using Vivado 2017.4 this upcoming monday and post an updated.
    Joshua
  • jdehaven
    0 jdehaven over 7 years ago
    We are now up and running!
    The problem we had was that when we clicked on the Xilinx ->Program Flash tool, the “FSBL File” entry was either empty or pointing to Periph_Test.elf.  Once we figured out that we needed to chang this to the FSBL from a Zynq_FSBL application, everything worked.
    I’m not sure if this field is supposed to autopulate, or just uses the most recently used elf file.
    Perhaps this should be clarified in the next version of the tutorial.
  • jdehaven
    The customer is up and running on his MiniZed.  The problem he had was that when he clicked on the XilinxàProgram Flash tool, the “FSBL File” entry was either empty or pointing to Periph_Test.elf.  Once we figured out that we needed to changed this to the FSBL from a Zynq_FSBL application, everything worked.
  • swhisenh
    0 swhisenh over 7 years ago
    I had the same issue with MiniZed Tutorial #4 and SDK 2017.4. The post above helped resolve the issue. I would add that for the FSBL file I entered the path to ZED_FSBL.elf that was created in the ZED_FSBL tutorial steps, and was then able to program and boot from flash successfully.
  • liparrok
    0 liparrok over 7 years ago in reply to swhisenh
    Had same issue, and that works for me too. Thanks
