    • Avnet Boards Community
PicoZed Hardware Design Possible "typo" on schematics for Picozed 7020 revE
  • Subscribers 307 subscribers
  • Views 354 views
  • picozed
mike.mandeville
mike.mandeville over 5 years ago
In SOM schematic jx3 pin 88 is not available for Z7020 but is in connector going to bank13 is not under yellowed area. I think this is an error
and it should be also marked as for 7015/30 only. Right?   We are making proto 2 and I could not find FPGA pin for this in z7020.
It is easy to move so only minor issue I guess.
This signal is showing in the FMC connector … BANK13_LVDS_12N
… but they don’t bring that signal back to the FPGA in Bank 13.  Pictures attached.
  • drozwood90
    drozwood90 over 5 years ago
    Hi there,
    Thanks for posting!
    The 7010/7015/7020/7030 are packages that able to migrate between and all share a single Carrier Card.  The JX connectors needed to have a super set of all boards.
    From the 7010/7020 schematic, there is a note to alert users about this LVDS pair
    If you look at the PicoZed 7015/7030 schematic, you can see the pins attached to the larger part:
    --Dan
