PicoZed Hardware Design Asking for the right type of transceiver connectors on PicoZed FMC Carrier Card V1
  • Replies 7 replies
  • Subscribers 347 subscribers
  • Views 801 views
jcy
jcy over 9 years ago
Here are the site of my picture, which shows the real style of connectors on my carrier card.
/sites/default/files/u124961/connector.jpg
  • jcy
    0 jcy over 9 years ago
    I want to know the real type of the transceiver connectors(J15, J16, J19-22) on PicoZed FMC Carrier Card V1, because in the user guide, they are described as SMA, however, the real type of these connectors are not SMA, but I really don't know  the exacat type of them. If you know the answer of my problem, please tell me the type of these connectors. Thank you very much.
  • jcy
    Here are the real picture of these connectors.
  • jcy
  • drozwood90
    0 drozwood90 over 9 years ago
    Hi there,
    I do not see pictures attached.  Typically you will need to place pictures on a file sharing site.
    I can confirm that the connectors are in fact SMA connectors for J15, J16, J19, J20, J21, J22
    The manufacturer is: CINCH CONNECTIVITY
    The part number is:  142-0711-202
    They are 50ohm nominal rated SMA style
    You will find the datasheet listed on the product page under products.avnet.com - enter the above part number and search.
    --Dan
  • jcy
    0 jcy over 9 years ago in reply to drozwood90
    Thank you for your help, Dan. Although the user guide describes the connector as SMA,  but I am sure the real style of the connector of the Carrier Card is not SMA, it seems like MCX, but I can't confirm the accurate style of it,  Here are the site of my picture, which shows the real style of connectors on my carrier card.  /sites/default/files/u124961/connector.jpg
  • drozwood90
    JCY,
    Please send me a private message with your order number and where you procured the board so that we can get this sorted.
    That image shows the wrong connectors on there and we should get to the bottom of this. I am certain that we called out SMA connectors, as I have multiple FMCv1 and FMCv2 boards here in my office - all of which contain SMA connectors.
    You can also see this on the Bill of Materials line item 55.
    [picozed.org -> support  -> documentation  -> related parts -> FMC V1 (click View)  -> PicoZed FMC Carrier BOM Rev C ]
    --Dan
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello All,
    For reference, here is a picture of the mispopulated SMA connectors.
    For more information please refer to the PicoZed FMC Carrier Card V1 errata document.
    http://picozed.org/support/documentation/4701
    Or this forum post addressing the issue.
    http://zedboard.org/content/picozed-fmc-carrier-card-v1-sma-connector-issue
    --Josh
