    • Avnet Boards Community
PicoZed Hardware Design Setting up synthesizer on FMC carier card v2
  • Subscribers 305 subscribers
  • Views 463 views
botenik
botenik over 6 years ago
Hi, I've tried to set up the synthesizer as mentioned in:
| Zedboard
in "Transceiver Clock Programming Reference Design". But I have problem with it, cause I'm using Vivado 2018.3.
I stopped at example 2. When I opened the TCL Shell, it told me that I need Vivado 2015.4 to use this project. How I can fix/avoid this problem?
Thanks.
  • jafoste4
    jafoste4 over 6 years ago
    My suggestion would be to use Vivado 2015.4 as that is what the reference design is targeting. A lot has changed since Vivado 2015.4 and 2018.3, if you are able to work around your issues please relay them back as I am sure that info will help others!
    -Josh
  • botenik
    If we use tcl scripts, so in one of them sets needed vivado version to 2015.4. I've found this script.
    So I will change there the version to 2018.3. In Monday will write what happen
  • botenik
    I've changed the needed vivado version to 2018.3 in file:
    *\hdl-pz_fmc2_valtest_PZ7030_FMC2_20160510_224006\Scripts\make.tcl
    It must work, because tcl is Tool Command Language, that independent from vivado version.
    But I got two errors due to unspecified ports of the chip:
    [DRC NSTD-1] Unspecified I/O Standard: 77 out of 208 logical ports use I/O standard (IOSTANDARD) value 'DEFAULT'
    and other same error.
    Troubleshooting described here: https://www.xilinx.com/support/answers/56354.html
    (You need to modify file: *\Scripts\ProjectScripts\pz_fmc2_valtest.tcl).
    Implementing is complete but project still not workig yet, soon will write more
  • botenik
    Project generated, but there are problems with creating pzcc_iic_eeprom_test.elf
    Because of this BOOT.file is not generating
    Here is log of the error:
    will write after solving
