PicoZed SDR Software-Defined Radio IP Core PicoZed
  • Subscribers 332 subscribers
  • Views 440 views
IP Core PicoZed
Former Member over 9 years ago
I'm recently working on  PicoZed Board, but searching through https://wiki.analog.com/resources/fpga/docs/hdl for examples already done, i realized the majority of them are not available for download.
I want know if some of you have already downloaded them, and could provided me some link of download or there IP CORE files.
Thanks.
  • drozwood90
    0 drozwood90 over 9 years ago
    Hi there,
    ADI's code is available for download in their repository:
    https://github.com/analogdevicesinc/hdl/
    I believe the support forum for ADI is located here:
    https://ez.analog.com/welcome
    If you are searching for Avnet's IP, we are working to create a repository of IP, however most of our IP is embedded into projects at this point.
    You can locate the Avnet HDL IP repository here:
    https://github.com/Avnet/hdl
    Any projects that use IP from that folder are good examples of the scripted flow for this.  The Touch Display, or for something more simple - however probably does not work with current versions of Vivado, the UNMAINTAINED sampleproject.tcl for instance.  You can see the flow and which scripts and what fields are bring filled in.
    --Dan
  • mbrown
    0 mbrown over 9 years ago
    Please also be sure to bookmark the Analog Devices wiki page for PicoZed SDR, which lists the available design examples.  As Dan said, all source code is available on their GitHub page.
    https://wiki.analog.com/resources/eval/user-guides/picozed_sdr
    /Matt
