    • Avnet Boards Community
Software Application Development JTAG linux boot hangs
  • Subscribers 312 subscribers
  • Views 462 views
We have a rev D ZedBoard and v2014.1 of the Xilinx tools.  I am working my way through the tutorials in zedboard_CTT_v2013_2_130807.pdf from zedboard_CTT_v2013_2_130807.zip.  Because it is for v2013.2 there have been a number of issues I've had to get around, but I'm stuck on this one.
In chapter 5 "Booting Linux and Application Debugging Using SDK", I got as far as beginning the linux boot (5.2.3 step 7).  Some time into the boot the ZedBoard hangs, suspiciously after some non-ASCII output.  The terminal output is attached below.
When the jumpers are in SD card boot configuration it boots the out-of-the-box linux on the SD card.
Terminal output:
U-Boot 2011.03-00226-gd4000b9 (Jun 07 2012 - 18:04:19)
DRAM:  512 MiB
MMC:   SDHCI: 0
Using default environment
In:    serial
Out:   serial
Err:   serial
Net:   zynq_gem
Hit any key to stop autoboot:  0
zed-boot> go 0x8000
## Starting application at 0x00008000 ...
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0
Linux version 3.3.0-14.2-build1-01464-ged63a4d (training@ubuntu) (gcc version 4.6.1 (Sourcery CodeBench Lite 2011.09-50) ) #1 SMP PREEMPT Wed Jun 20 14:46:29 PDT 2012
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Xilinx Zynq Platform, model: Xilinx Zynq ZedBoard
bootconsole [earlycon0] enabled
Memory policy: ECC disabled, Data cache writealloc
On node 0 totalpages: 126976
free_area_init_node: node 0, pgdat c045c1c0, node_mem_map c1001000
  Normal zone: 1152 pages used for memmap
  Normal zone: 0 pages reserved
  Normal zone: 125824 pages, LIFO batch:31
PERCPU: Embedded 7 pages/cpu @c1486000 s5696 r8192 d14784 u32768
pcpu-alloc: s5696 r8192 d14784 u32768 alloc=8*4096
pcpu-alloc: [0] 0 [0] 1
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 125824
Kernel command line: console=ttyPS0,115200 root=/dev/ram rw initrd=0x800000,8M earlyprintk maxcpus=2 debug ip=192.168.1.10
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 240MB 256MB = 496MB total
Memory: 490028k/490028k available, 34260k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
    lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc0409c4c   (4104 kB)
      .init : 0xc040a000 - 0xc042e640   ( 146 kB)
      .data : 0xc0430000 - 0xc045dba0   ( 183 kB)
       .bss : 0xc045dbc4 - 0xc0477e1c   ( 105 kB)
Preemptible hierarchical RCU implementation.
        Verbose stalled-CPUs detection is disabled.
NR_IRQS:128
xlnx,ps7-ttc-1.00.a #0 at 0xe0800000, irq=43
Console: colour dummy device 80x30
Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
smp_twd: clock not found: -2
Calibrating local timer... 333.55MHz.
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
Setting up static identity map for 0x2f11d8 - 0x2f120c
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (2664.03 BogoMIPS).
devtmpfs: initialized
NET: Registered protocol family 16
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x72060000, Cache size: 524288 B
registering platform device 'pl330' id 0
registering platform device 'arm-pmu' id 0
------------[ cut here ]------------
WARNING: at arch/arm/kernel/hw_breakpoint.c:235 enable_monitor_mode+0x30/0xb0()
halting debug mode enabled. Unable to access hardware resources.
Modules linked in:
[<c0012928>] (unwind_backtrace+0x0/0xe0) from [<c001e84c>] (warn_slowpath_common+0x4c/0x64)
[<c001e84c>] (warn_slowpath_common+0x4c/0x64) from [<c001e8e4>] (warn_slowpath_fmt+0x2c/0x3c)
[<c001e8e4>] (warn_slowpath_fmt+0x2c/0x3c) from [<c00135b0>] (enable_monitor_mode+0x30/0xb0)
[<c00135b0>] (enable_monitor_mode+0x30/0xb0) from [<c00136a4>] (reset_ctrl_regs+0x74/0x130)
[<c00136a4>] (reset_ctrl_regs+0x74/0x130) from [<c005223c>] (generic_smp_call_function_single_interrupt+0xe4/0x124)
[<c005223c>] (generic_smp_call_function_single_interrupt+0xe4/0x124) from [<c0011be8>] (handle_IPI+0xc4/0x164)
[<c0011be8>] (handle_IPI+0xc4/0x164) from [<c00084c0>] (gic_handle_irq+0x90/0x9c)
[<c00084c0>] (gic_handle_irq+0x90/0x9c) from [<c000d240>] (__irq_svc+0x40/0x70)
Exception stack(0xdf867fa0 to 0xdf867fe8)
7fa0: df866000 df866028 df867fe8 00000000 c043b698 00000015 10c0387d c045df60
7fc0: 0000406a 413fc090 00000000 00000000 00000000 df867fe8 c000e02c c000e030
7fe0: 60000013 ffffffff
[<c000d240>] (__irq_svc+0x40/0x70) from [<c000e030>] (default_idle+0x24/0x28)
[<c000e030>] (default_idle+0x24/0x28) from [<c000e1dc>] (cpu_idle+0x3c/0xa4)
[<c000e1dc>] (cpu_idle+0x3c/0xa4) from [<00423d54>] (0x423d54)
---[ end trace 1b75b31a2719ed1c ]---
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: halting debug mode enabled. Assuming maximum watchpoint size of 4 bytes.
xslcr xslcr.0: at 0xF8000000 mapped to 0xE0808000
bio: create slab <bio-0> at 0
gpiochip_add: registered GPIOs 0 to 245 on device: xgpiops
xgpiops e000a000.gpio: gpio at 0xe000a000 mapped to 0xe080a000
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Switching to clocksource xttcpss_timer1
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 5, 196608 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 8192K
xscugtimer xscugtimer.0: ioremap fe00c200 to e080c200 with size 400
pl330 dev 0 probe success
JFFS2 version 2.2. (NAND) (SUMMARY)  u00C2u00A9 2001-2006 Red Hat, Inc.
msgmni has been set to 973
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
e00u00BDu00BDu00B9u00CDu00BDu00B1u00A5u00CDu00E5AMuu00B9
u00B1u00BDu00B9u00BAr"u00D9loop: module loaded
GEM: BASEADDRESS hw: e000b000 virt: e0862000
XEMACPS mii bus: probed
    The 2013.2 version of the ZedBoard Concepts Tools and Techniques tutorial has a couple of errors. One of them is that the hardware build used for the Linux exercise in Chapter 5 does not have the Ethernet portion of the design that the Linux OS is expecting.
    You could go back and add the Ethernet to the hardware design or look at what another forum poster did to work around the issue:
    http://www.zedboard.org/content/problem-chapter-5-zedboardctt-tutorial
    -Gary
    Gary you're beautiful!  Will you marry me?!
    That's the answer.  Shame I didn't find it when I searched for it.  Must have used all the wrong keywords.
    Cheers,
    Steve
