    Members
    • Experts & Guidance
    • Avnet Boards Community
    • 'Choose another store...'
Software Application Development AXI_DMA device driver for Linux
Avnet Boards Forums requires membership for participation - click to join
  • Replies 28 replies
  • Subscribers 177 subscribers
  • Views 1920 views
Does any one know how to use the AXI_DMA device driver linux-xlnx/drivers/dma/xilinx_dma.c?
Does it work, has anyone tested it for AXI_DMA IP?
I need to use it as a module.
I have a bare metal AXI_DMA driver but porting it to Linux seems more complicated than I though.
I am new to Linux device drivers, this might be a trivial question for some of you.
Silviu
    Hi Silviu,
    I use VDMA IP. I try to use exactly same driver, but without succeed. I dont know how to use it. I found information about xvdma.c driver (http://forums.xilinx.com/t5/Embedded-Linux/Xvdma-Driver/td-p/279964) who works as bridge between base VDMA kernel driver and user application, but I am not able to colmpile it. I spent 2 days without succeed.
    My final solution is easy. I use mmap to access VDMA IP registers and program it. I have working solution after 2 hours.
    Linux is little hell. :-)
    Hi Vatu,
    Can you please share the code that uses mmap to control the driver from user space?
    Thank you,
    Silviu
    0 Former Member over 10 years ago in reply to Former Member
    Hi Vatu,
    In my case AXI DMA is at 0x40400000 but
    mmap() needs a file descriptor, fd.
    How do you create this fd if there is only a physical address that I need to access?
    Can fd be NULL?
    Does it mean that there must be a driver running already?
    Do I need to configure the device-tree file before I use the mmap()?
    Hi Silviu,
    hete is my solution http://www.arbot.cz/post/2013/03/20/VDMA-on-ZedBoard.aspx.
    Hi Silviu,
    you can use fd=open("/dev/mem", O_RDWR) to get file descriptor.
    Function mmap maps physical addres to virtual adress space.
    mmap(NULL, <length>, PROT_READ | PROT_WRITE, MAP_SHARED, fd, <physical adress>);
    This solution access directly to VDMA IP registers, therefore you does not need any driver.
    You does not need instantiate any driver in device-tree, but is good idea to limit memory used by kernel to reserve physical memory for store data by DMA engine.
    Thanks, I spent more time reading a device driver book and I got to the same conclusion. The quick way to drive and get data from the AXI-DMA device is with mmap function. After that is like a bare metal driver.
    Another interesting way is to implement a small character driver that redefines the mmap to map it to a physical address. In theory you can use kmalloc() convert its return address to physical address with virt_to_phys().
    But I get a fragmentation issue  when using kmalloc().
    Thanks for your help,
    Silviu
    Thanks, it helps a lot.
    Silviu
    Hi Vatu,
    How do you invalidate the cache for one of your mmap regions?
    Silviu
    Hi Silviu,
    I have not yet figured out.
    One option is use ACP.
    Functional solution is interesting for me.
    Vatu
    Hi Vatu,
    A user space driver is like this:
    int dma_initUser(DmaDevId_t devid, XAxiDma_User_t *pUserConfig)
    tconst XAxiDma_Config_t *pPhyConfig;
    tint fd;
    tvoid *vAddr;
    tpPhyConfig = LookupConfig(devid);
    tprintf("DMA phys addr = 0x%x
    ", (int)pPhyConfig->physDmaAddr);
    t//-------------------------------------
    t//Get base virtual address for the DMA registers
    tfd = open("/dev/mem", O_RDWR | O_SYNC);
    tpUserConfig->fd = fd;
    tvAddr = mmap(NULL, pPhyConfig->dmaSize,
    tttPROT_READ | PROT_WRITE,
    tttMAP_SHARED, fd,
    tttpPhyConfig->physDmaAddr);
    tif(vAddr == MAP_FAILED) {
    ttgoto mmap1_err;
    t}
    tpUserConfig->virtDmaAddr = (u32)vAddr;
    tpUserConfig->dmaSize = pPhyConfig->dmaSize;
    t//Get virtual address for the DMA RX buffer
    tvAddr = mmap(NULL, pPhyConfig->buffPoolSize,
    tttMAP_SHARED, fd,
    tttpPhyConfig->physBuffAddr);
    ttgoto mmap2_err;
    t}
    tpUserConfig->virtBuffAddr = (u32)vAddr;
    tpUserConfig->physBuffAddr = pPhyConfig->physBuffAddr;
    tpUserConfig->buffPoolSize = pPhyConfig->buffPoolSize;
    tpUserConfig->fpgaPktSize = pPhyConfig->fpgaPktSize;
    tpUserConfig->devid = pPhyConfig->DeviceId;
    treturn 1;
    mmap1_err:
    tperror("[dma_driver]ERROR: DMA mmap() failed
    tclose(fd);
    tassert(0);
    mmap2_err:
    tperror("[dma_driver]ERROR: Buffer mmap failed
    tmunmap((void*)pUserConfig->virtDmaAddr, pUserConfig->dmaSize);
    tclose(fd);
    tassert(0);
An Avnet Company © 2023 Premier Farnell Limited. All Rights Reserved.
