Software Application Development How to run a Hello world application on linux platform on zynq board?
  • Subscribers 363 subscribers
  • Views 532 views
I implemented some application on standalone processor.Now I want to develop an application which will be run on linux os.I booted linux os from SD card successfully.Now what will be the next step to run a simple hello world application on it?Is there any need to install gcc compiler on linux platform or will SDK run it?
    1. Install Xilinx tools onto a Linux machine.
    2. Set your PATH (in my case /opt/Xilinx/14.6/ISE_DS/EDK/gnu/arm/lin/bin).
    3. Set your compiler to user arm-xilinx-linux-gnueabi-gcc
    In first step you said that Install xilinx tools onto a Linux machine.That means i have to install xilinx tools on to sd card from where i boot linux?then how to install it?
    Did you get a solution of running a simple application on linux platform on zedboard?
    Well I am new to this board and trying to learn. I am using the linux that came with pre installed on the memory card.
    Can you also point out to some tutorials which I could use for reference.
    Thanks in advance!
