    Members
    • Experts & Guidance
    • Avnet Boards Community
    • Or choose another store...
Software Application Development PS7_Ethernet_0 failed in Mini-ITX peripheral test app
Avnet Boards Forums requires membership for participation - click to join
  • Subscribers 175 subscribers
  • Views 132 views
Former Member over 8 years ago
I have noted the following error while running a peripheral test sample project (created in SDK). This project only contains the ZYNQ PS alone, no additional PL blocks.
This error did NOT appear when using the reference package zynq_mini_itx_7z100_embedded_design_v2015_2.zip.
Running Interrupt Test  for ps7_ethernet_0...
Error detect phy
This project is created under Vivado 2015.2 (SDK). Only the following section of code is added to reset the Phy. No other user code added.
// PHY Reset
int Delay;
XGpioPs_Config *ConfigPtrPS;
ConfigPtrPS = XGpioPs_LookupConfig(0);
XGpioPs_CfgInitialize(&mio_resets, ConfigPtrPS,
   tttConfigPtrPS-BaseAddr);
XGpioPs_SetDirectionPin(&mio_resets, MIO_47, 1);
XGpioPs_SetOutputEnablePin(&mio_resets, MIO_47, 1);
XGpioPs_WritePin(&mio_resets, MIO_47, 0x0);
  for (Delay = 0; Delay < RESET_DELAY; Delay++);
  XGpioPs_WritePin(&mio_resets, MIO_47, 0x1);
// End PHY Reset
The above code is copied from "testperiph.c" of zynq_mini_itx_7z100_embedded_design_v2015_2.zip.
I am not able to figure out what is causing the error.
Would appreciate if someone could advise on what could possibly be the cause of the error (which was not observed with the reference package).
Thanks and Regards.
Sim CK
    0 Former Member over 8 years ago
    Are you saying you added the PHY reset code to your testperiph.c and the test still fails?
    If you have not added this code to your file, you need to do that. The PS MIO[47] on the board resets the PHY and it defaults to active state. The reset code will set the MIO[47] to '1' to de-assert it.
    0 Former Member over 8 years ago in reply to Former Member
    I have noted that the MDIO lines were not assigned at the PS side. :)
    Mystery resolved.
An Avnet Company © 2023 Premier Farnell Limited. All Rights Reserved.
