We are using 2014.4 for Vivado/SDK/Petalinux, the hardware engineer create .hdf file under window vivado, I took this file and tried to generate Hardware Platform Specification using SDK under Ubuntu linux machine, I got following error:
ERROR: [Common 17-273] Failed to open zip archive /opt/project/try/tryProj/subsystems/linux/hw-description/system.hdf. This may indicate that the file is corrupt.
ERROR: [Hsi 55-1451] Error: running open_hw_design.
Anybody knows how to fix the problem? I also tried, generate Hardware Platform Specification under window SDK which has no problem, but failed at same error when trying to run petalinx-config for my project. I guess it's format difference between window and linux, but don't know how to fix this.
We are using zedboard.
