Ultra96 Hardware Design Ultra96-v2 mini-DP to HDMI adapter
  • Replies 14 replies
  • Subscribers 369 subscribers
  • Views 6672 views
skiphs
skiphs over 7 years ago
I've been trying to get the Ultra96-v2 to work with an HDMI display, and have been running into quite a bit of trouble.
The official documentation recommends Ableconn DPHD4K0AA, which doesn't appear to be available anywhere online.
Given that, I figured I'd try a different active mini-DP to HDMI adapter. The issue is I haven't really been able to get any to work.
Every time the same issue occurs: I can turn the device on, but there's never a display. However, if I wait about two minutes and press the reset button the device reboots and the display works perfectly.
So far I've tested:
4x Displays - HP Pavilion 25xw / TOGUARD 12" Inch IPS / Acer XB271HU / Dell 2408WFP
2x HDMI Cables
2x Active mini-DP to HDMI adapters - Cable Matters / Plugable
2x SD Card Images - Pynq / Ultra96v2 OOB
Interestingly enough, on Pynq I'm able to get the display working by ssh'ing in after two or so minutes and running:
xrandr -d :0 --auto
xrandr -d :0 -q
xrandr -d :0 --output DP-1 --mode 1920x1080
This may also work on the OOB image, I haven't tried.
Additionally, using mini-DP to DisplayPort appears to work just fine. However, the display I'd like to use does not have a DisplayPort input.
Does anyone know how to get this working, or another verified mini-DP to HDMI adapter?
  • martijnberger
    0 martijnberger over 7 years ago in reply to clem57
    The issue is the display port side,
    the chip support RBR, HBR and not HBR2 so ( 1.62, 2.70 and not 5.40 Gbit/s per lane)
  • clem57
    0 clem57 over 7 years ago in reply to martijnberger
    Thanks martijnberger , now I understand.
  • jiapei100
    0 jiapei100 over 6 years ago in reply to skiphs
    Hey, Christopher?
    Is your cable CD0095 working ?
    I got one from https://www.amazon.com/gp/product/B01FM50QJC/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1  , it seems it's NOT working properly, and always showing:
    HDMI 1
    No Signal
    (1) Check the cable connections and the settings of your source device.
    (2) Press SOURCE on your remote to select connected source device.
    Can you please provide your CD0095 linkage? Thank you very much.
    Pei
  • bhfletcher
    0 bhfletcher over 6 years ago in reply to jiapei100
    Pei,
    Please confirm that you are using the Active version. That's what your link took me to, but there are other passive options on that page that won't work. Did you buy the $12.99 or $21.99 versions?
    Which design are you booting? Is it booting properly? You need to have something that drives miniDP, like Avnet's out-of-box design.
    Are you sure the monitor is working? Not all monitors work. Is it a 1080p monitor or something else?
    Bryan
