Ultra96 Hardware Design Xilinx Petalinux 2024.1 Stuck on BL31 using u96v2_sbc_base
  • Subscribers 345 subscribers
  • Views 994 views
  • ultra96v2
  • petalinux
JackBonnellDev
JackBonnellDev over 1 year ago
Hey guys currently trying to build a petalinux image using the make_u96v2_sbc_base.tcl vivado block design from Avnet/HDL but it keep hanging on the below message seen on the uart output:
My steps for creating the petalinux image:
  1. petalinux-create --type project --template zynqMP --name u96v2_sbc_base
  2. cd u96v2_sbc_base
  3. cd project_spec && git clone --branch 2024.1  https://github.com/Avnet/meta-avnet.git
  4. petalinux-config --get-hw-description ../u96v2_sbc_base.xsa
    • DTG Settings -> MACHINE_NAME -> "avnet-ultra96-rev1"
    • Image Packing Configuration -> Root filesystem type -> EXT4
    • Yocto Settings -> Yocto Machine Name -> "u96v2-sbc-base"
    • Yocto Settings -> User Layers -> Add new layer
      • ${PROOT}/project-spec/meta-avnet
  5. petalinux-build -c avnet-image-minimal
  6. petalinux-package --boot --fsbl ./images/linux/zynqmp_fsbl.elf --fpga ./images/linux/system.bit --u-boot --force
  7. petalinux-package --wic
  8. Flash petalinux-sdimage.wic onto a 16GB sd card using balenaEtcher.
  9. Open Putty on COM6 with 115200 speed.
  10. see output above
  • Ratin
    0 Ratin over 1 year ago
    Does this image work?
    www.avnet.com/.../Ultra96v2_Factory_Image_Write_190611.zip
  • JackBonnellDev
    0 JackBonnellDev over 1 year ago in reply to Ratin
    it does yes
  • Ratin
    0 Ratin over 1 year ago in reply to JackBonnellDev
    It sounds like a chain-of-trust issue within the Arm trusted FW, I think you have to look into how the Arm trusted FW code (the bl31 source code) is generated - make sure there is no error in building it.
