ZedBoard Hardware Design EXTENSION Cable for FMC adaptor on zedboard
  • Subscribers 341 subscribers
  • Views 452 views
Former Member over 7 years ago
Does anybody have used the FMC extension cable for Zedboard . I want to use it for FMCOMS2.. so to reduce the form factor of zedboard SDR. instead of facing out I want to change the direction of FMCOMS2 mounting to reduce farm factor .
Another question, does anybody can tell me that is microzed is pin compatibleIN TERMS OF  FMC, ETHERNET AND PMOD PINS  with zedboard
  • jafoste4
    0 jafoste4 over 7 years ago
    Hello CTC,
    No the MicroZed is not Pin compatible with Zedboards FMC and Pmods as the MicroZed only has a single PMOD and requires a Carrier Card to access the FMC. The MicroZed also comes in 2 versions. A 7010 and 7020 device.
    --Josh
