    • Avnet Boards Community
ZedBoard Hardware Design Zed Board
Avnet Boards Forums requires membership for participation - click to join
  • Replies 44 replies
  • Subscribers 300 subscribers
  • Views 2511 views
Zed Board
100aditya
100aditya over 8 years ago
Dear Sir/Madam,
                             In mine project i want to send data from ubuntu PC to ZedBoard using Wifi. I got one link http://zedboard.org/product/wilink-8-adaptor which talks about some kind of Wifi adpater for Micro-zed.
         Will this link and its given documents be seamlessly used with ZedBoard.
Regards
Aditya
  • 100aditya
    0 100aditya over 8 years ago
    Hi Josh,
                  Now mine problem got resolved.Actually i found mine cable was faulty because of which USB-UART port was not showing up in the device manager. Next thing that i do not understand is following... I am proceeding with Lab 5 s/w tutorial. In this we have to do the Memory test. Again i just followed the lab instruction but i am getting different results. Here is the screen shot of lab 5 tutorial result after running the Memory_test :-
     --------------------Starting Memory Test Application----------------------------
    NOTE: This application runs with D-Cache disabled.As a result, cacheline requests will not be generated
    Testing memory region: ps7_ddr_0
        Memory Controller: ps7_ddr
             Base Address: 0x00100000
              32-bit test: PASSED!
              16-bit test: PASSED!
               8-bit test: PASSED!
    Testing memory region: ps7_ram_1
        Memory Controller: ps7_ram
             Base Address: 0xffff0000
               8-bit test: PASSED!
    ---------------------Memory Test Application Complete----------------------
    But when i am running i am getting the following results on mine SDK console:-
      -------------------------------Starting Memory Test Application---------------------------------
                 8-bit test: PASSED!
                 8-bit test: PASSED!
      Testing memory region: axi_bram_ctrl_0
          Memory Controller: axi_bram_ctrl
               Base Address: 0x40000000
                32-bit test: FAILED!
                16-bit test: FAILED!
                 8-bit test: FAILED!
      -----------------------Memory Test Application Complete----------------------
    So as you can notice evrything is fine ,but in lab tutorial there is no result for
    memory region: axi_bram_ctrl_0 but when i am running the Memory test applicartion in which memmory region :axi_bram_ctrl_0 is being tested and result is FAILED. I want to know the reason behind this????
    Regards
    Aditya
  • 100aditya
    Hi Josh,
               8-bit test: PASSED!
               8-bit test: PASSED!
                 8-bit test: PASSED!
                 8-bit test: PASSED!
                 8-bit test: FAILED!
    Regards
    Aditya
  • 100aditya
    0 100aditya over 8 years ago in reply to 100aditya
    Hi Josh,
               8-bit test: PASSED!
               8-bit test: PASSED!
                 8-bit test: PASSED!
                 8-bit test: PASSED!
                 8-bit test: FAILED!
    Regards
    Aditya
  • 100aditya
    Hi Josh,
                                   I am using the SDK (WEB WDITION 2014.4). In SDK under New--->File---> Appliction Project i have created a prohect named zynq_fsbl_0. Now in this project i am trying to add Xilinx templete Zync FSBL and it is showing the following error:-
              "This application requires xilffs library in the Board Support Package".
    When i looking the library in mine existing BSP, there is only file which is named libxil.a. Please tell me how to add this xilfss library in mine exixsting BSP.
    Regards
    Aditya
  • jafoste4
    0 jafoste4 over 8 years ago
    Hi Aditya,
    Your creating a new BSP with the fsbl application correct? It should enable itself when you go to create the application(It just worked for me). To double check that it is enabled do the following. In the project explorer, open up the system.mss file that is in the fsbl_bsp. In the opened system.mss file click on Modify this BSP's Settings. Thats where you can see if the xilffs is enabled.
    --Josh
  • 100aditya
    0 100aditya over 8 years ago in reply to jafoste4
    Hi Josh,
                      Thanks for reply. mine problem got resolved. Actually in erlier BSP xilfss lib were not include. So again i included the xilfss library by going into BSP configuration setting and again building the BSP.
    Regards
    Aditya
  • 100aditya
    Hi Josh,
                    Actually i was going through the s/w tutorial--> Lab 9(Dual Processor) ,in which under experiment no 2 , our task was to  ""Creating Bare-Metal Application Project for CPU1",. But when i tried to follow the instruction and craeted the BSP for CPU1 ,i got the following error.
    14:40:01 ERROR :  [Hsi 55-1545] Problem running tcl command ::sw_standalone_amp_v3_11_a::generate : invalid command name "xget_libgen_proc_handle"
        while executing
        (procedure "::sw_standalone_amp_v3_11_a::generate" line 8)
        invoked from within
    "::sw_standalone_amp_v3_11_a::generate standalone_amp"
     [Hsi 55-1442] Error(s) while running TCL procedure generate()
    14:40:01 ERROR : Failed to generate BSP.
    14:40:01 INFO : BSP Project P/app_cpu1_bsp has been successfully migrated.
    14:41:10 ERROR :  [Hsi 55-1545] Problem running tcl command ::sw_standalone_amp_v3_11_a::generate : invalid command name "xget_libgen_proc_handle"
        while executing
        invoked from within
    14:41:10 ERROR : Error generating bsp sources: Failed to generate BSP.
    14:41:10 ERROR : Failed to generate sources for BSP project app_cpu1_bsp
    org.eclipse.core.runtime.CoreException: Internal error occurred while generating bsp sources. Please check the SDK Log view for further details.
    at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler.internalGenerateBsp(RegenBspSourcesHandler.java:178)
    at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler.access$2(RegenBspSourcesHandler.java:163)
    at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler$1$1.run(RegenBspSourcesHandler.java:131)
    at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2345)
    at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler$1.run(RegenBspSourcesHandler.java:135)
    at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
    Could u please tell me why this error is coming and what is the remedy of this.
    Regards
    Aditya
  • 100aditya
    Hi Josh,
                     One more information regarding the error that i posted you just above is:-- In the problem window proveded in the SDK GUI is is showing that  make:***No Rule to make target 'all'": as an error while creating the the BSP for CPU1.  While giving your advice you can also take this as consideration.
    Regards
    Aditya
  • jafoste4
    Hi Aditya,
    In experiment 2, step 5 you add -DUSE_AMP=1 to the extra_compiler_flags. You did this correct? Also double check that you put a space infront of it. So based off of figure 16 it would look like "-g -DUSE_AMP=1". (see the space I put inbetween -g and Duse)
    --Josh
  • 100aditya
    Hi Josh,
                    Thanks for this subtle information. Now i came to mine room ,tomorrow i will apply this and let you know.
    Regards
    Aditya
