ZedBoard Hardware Design AMP Running Linux and Bare-Metal System on Both Zynq SoC Processors adapted for zedboard
  • Subscribers 344 subscribers
  • Views 616 views
Former Member over 9 years ago
Hi Everyone,
I am trying to utilize both cpu0 and cpu1 on zed board.
Using the document xapp1078,that document having operation of cpu0 on linux and cpu1 on bare-metal.
First, I downloaded the following generated files and copied to SD card them.
http://www.zedboard.org/sites/default/files/design/xapp1078_zedboard.zip,
<SD card>
- BOOT.BIN
- devicetree.dtb
- uImage
- uramdisk.image.gz
- rwmem.elf
- softUart.elf
After I switched on Zed Board,booting process has to start, and booting process(cpu0) was started,
but cpu1 was not started.
zynq > /mnt/rwmem.elf 0xffff8000
0x00000000ffff8000 = 0x00000000
zynq > /mnt/rwmem.elf 0xfffffff0 0x18000000
"0xffff8000"address remains unchanged "0x00000000".
Please provide a solution as soon as possible.
    0 Former Member over 9 years ago
    Take a look at the updated xapp1078 information here:
    http://www.wiki.xilinx.com/XAPP1078+Latest+Information
    -Gary
    0 Former Member over 9 years ago in reply to Former Member
    I followed the same procedure listed there. But I'm not able solve the problem. Please help me asap.
    You are going to have to be more specific as to exactly what you did and how it failed. Did you download and use the Vivado 2014.4 version of the files? Exactly what steps did you take to implement the project?
    -Gary
    I downloaded the files from the link http://www.zedboard.org/sites/default/files/design/xapp1078_zedboard.zip
    and copied the files to SD card from the folder xapp1078_zedboard/design/work_zedboard_14_3/zedboard_osl3_8_kernel_sdcard/*
    booted through sd card.
    zynq>/mnt/softUart.elf &
    zynq>/mnt/rwmem.elf 0xffff8000
    zynq > /mnt/rwmem.elf 0xfffffff0 0x18000000 (zedboard modified address)
    value at 0xffff8000 should be incrementing but it's not. Cpu1 is not starting. I want to know where exactly cpu1 address starts.
    As mentioned above I suggest you download the more recent 2014.4 based version files and give that a try. Using Vivado 2014.4 will improve your chances of success as well.
    -Gary
