ZUBoard openocd working with zuboard at jtag boot mode?
  • Replies 10 replies
  • Subscribers 345 subscribers
  • Views 1652 views
  • ZUBoard
jiedummy
jiedummy over 2 years ago
Did any one get openocd working with zuboard at jtag boot mode, sw2[1:4]={on|on|on|on}?
openocd version: v0.12.0
  • padudle
    padudle over 2 years ago in reply to jiedummy +1
    I really wish they had just put a four-position dip switch on those lines.
  • FPGA_Zealot
    FPGA_Zealot over 2 years ago in reply to jiedummy +1
    There is a user alt boot mode that you can overwrite the hardlined boot pins. docs.xilinx.com/.../BOOT_MODE_USER-CRL_APB-Register
  • muhbay
    0 muhbay over 2 years ago
    In another forum   Using OpenOCD with Ultra96
    People say it is "The programming of the FTDI chip on the Ultra96 JTAG/UART adapter is proprietary to Xilinx.  Avnet cannot share this information publicly". AFAIK, SW2 JTAG mode is regarding to pure JTAG probe without using ftdi usb to jtag chip.
  • jiedummy
    0 jiedummy over 2 years ago
    finally I can use openocd with zub_1cg and other boards with zynqmp.  shared at "github.com/jiedummy/openocd-zynqmp".
    since board kv260_starter is hardwired as booting from qspi, it took me sometime to order part and tool to make it booting as jtag_mode.
    updated on 20240128:  added support of k24 som at "github.com/jiedummy/openocd-zynqmp".
  • padudle
    0 padudle over 2 years ago in reply to jiedummy
    Hello J,
    Can you describe what you did to change the boot mode on the KV260 Starter Kit?
  • jiedummy
    0 jiedummy over 2 years ago in reply to padudle
    populated R164 of mode pins.
  • padudle
  • jiedummy
    kv260 kit is not eval board.  however, avnet zub_1cg is good board to try different boot modes of zynqmp, and without noisy fan.
  • FPGA_Zealot
    0 FPGA_Zealot over 2 years ago in reply to jiedummy
  • jiedummy
    0 jiedummy over 2 years ago in reply to FPGA_Zealot
    does this method need accessing the register?
  • FPGA_Zealot
    Yes, but you can access it over JTAG via Vivado lab XSDB or Vitis XSCT.  You can also write a small program for the flash to configure that register via ARM SW on "normal" power-up, then the next reset will be JTAG boot.
  • jiedummy
    my goal is handling blank zynqmp without using xilinx tools, just with general gnu arm tools, since zynq soc is cpu oriented designs, not like last generation powerpc soc.
