ZUBoard Petalinux build fails on opencv_4.6.0.bb:do_compile
  • Subscribers 347 subscribers
  • Views 779 views
FCNewCo
FCNewCo over 1 year ago
Hi everyone,
I have an issue building petalinux for the ZUBoard (Zynqmp).
I created a petalinux project based on zub1cg_sbc_base_2023_1.bsp BSP
petalinux-create -t project -s zub1cg_sbc_base_2023_1.bsp
and I tried to build as is with "petalinux-build" but, after serveral hours, it fails with
ERROR: Task (../zub1cg_sbc_base_2023_1/components/yocto/layers/meta-openembedded/meta-oe/recipes-support/opencv/opencv_4.6.0.bb:do_compile) failed with exit code '1'
It seems there is something wrong in Opencv package.
Has someone already faced this issue ?
Thanks in advance.
Filippo
  • FCNewCo
    FCNewCo over 1 year ago +1
    Solved ! I thought to delete my question because the source of the problem is really stupid but it could probably help someone, who knows .. It was due to insufficient RAM ! I am building petalinux…
  • FCNewCo
    0 FCNewCo over 1 year ago
    Solved !
    It was due to insufficient RAM ! I am building petalinux in a virtual machine to which I dedicated 4GB of RAM.
    With 4GB petalinux build works perfectly for every other package but Opencv :-)
    Increased the RAM to 8GB and it compiled.
  • flyingbean
    0 flyingbean over 1 year ago in reply to FCNewCo
    Good to know the case with 4GB memory for Petalinux flow.
