ZUBoard ZUBoard baremetal SD boot problem
  • Replies 13 replies
  • Subscribers 357 subscribers
  • Views 1502 views
  • baremetal
  • ZUBoard
  • boot
  • sd
tony56887
tony56887 11 months ago
I'm unable to boot a simple baremetal app from the SD card. Very strange problem.
  • The ZUB will boot petalinux from the SD card just fine, I've built and booted the ZUB petalinux base and trifecta builds. All using the same SD card, several times.
  • I can build my simple baremetal app in Vitis and boot it over JTAG, as well as QSPI, which works fine. Attempting to boot from SD with FSBL debug messaging enabled, I get:
    • SD: Unable to open file 1:/BOOT.BIN: 3, XFSBL_ERROR_SD_F_OPEN
  • I also have an Ultra96v2. Using the same SD card, I can boot a simple u96 baremetal app from the SD card on the u96.
  • The SD card is a 16GB delkin. I format it FAT and copy my BOOT.bin to it, simple.
Everything works fine on the U96, and the ZUB, except SD boot from the ZUB only. This is very strange and I can't figure what the issue could be. Any ideas?
  • iksevas
    iksevas 11 months ago in reply to tony56887 +2
    I have heard stories of 16Gb cards not functioning on some boards but 8Gb cards working fine. I have heard stories of different manufacturers working better than others. So, I would not be surprised if…
  • tony56887
    tony56887 9 months ago in reply to adielement +1 suggested
    Solved yesterday. This was a tools issue on version 2023.2 on interface SD1. SD0 works fine as that's what ultra96 is targeting. Version 2024.2 has this fixed.
  • adielement
    0 adielement 9 months ago in reply to tony56887
    tony56887 said:
    I'm wondering if this "1:/" is prepended in the FSBL code due to booting from SD1 instead of SD0...
    You can print initSD function code statements and thier arguments (using printf or xil_printf, for debug purpose), to get reason why it is listing 1:/, either because of SD1 or anything else.
  • adielement
    0 adielement 9 months ago in reply to adielement
    tony56887  you can also verify WP and CD pins as per datasheet.
  • tony56887
    0 tony56887 9 months ago in reply to adielement
