EXPLORE-NFC
  • EXPLORE-NFC
EXPLORE-NFC
Forum According AN11480 4.3 ??
Join EXPLORE-NFC to participate - click to join for free!
  • Replies 11 replies
  • Subscribers 10 subscribers
  • Views 3121 views
ageens
ageens over 7 years ago
According AN11480 43:
1. Copy the zip compressed software onto an USB Stick.
4. Change into the directory that contains the extracted files with the command:
cd ~/<directory of extracted files>/
5. Install the files with the command:
sudo dpkg -i libneardal0_<version>_armhf.deb neardexplorenfc_<version>_armhf.deb
Where “<version>” needs to be substituted with the real version strings
contained in the file names.
1. Which software packet needs to be downloaded.
5. I tried different available software packets eg SW282816. But then 5) is i think outdated.
Some advice plse
albert.geens@vdab.be
  • jomoenginer
    0 jomoenginer over 7 years ago
    I'm not sure if it were intended but your username is showing up with your email address for those not logged in.
  • ageens
    0 ageens over 7 years ago in reply to jomoenginer
    I used my email address as login name. Is that not good practice or do you mean something else.
  • jomoenginer
    0 jomoenginer over 7 years ago in reply to ageens
    I you have no issue with the world seeing your email address, then I guess it is not an issue.  Typically, a username would be used and the email would be used to tie the account to.
    Look at your posts without being logged into the element14 site and see what I am referring to.
    0 Jan Cumps over 7 years ago
    Looking at that 9. References section of the application note, the software should be available here:
    https://www.nxp.com/products/identification-and-security/nfc/nfc-reader-ics/explore-nfc-exclusive-from-element14:PNEV512…
  • ageens
    0 ageens over 7 years ago in reply to Jan Cumps
    Thks for the reply, but that is just the problem.;
    I downloaded all the packages, with none of them was i able to install (ref 5.)
    contained in the file names."
  • jomoenginer
    What error are you seeing when you run the commands?
    Also, what are the .deb files names you have that you are trying to install?
    It might be helpful to provide the exact command string you are using to install these files.
  • ageens
    Ref: EXPLORE NFC Board for Raspberry Pi
    Used:
    SW282816 Neard EXPLORE-NFC Dev â?? Using NeardAL with EXPLORE-NFC. (.zip)
    .zip contains:
    >> libneardal-dev_0.14.3-1_armhf.deb
    >>neard-explorenfc_1.2.orig.tar.gz
    >> neard-explorenfc_1.2-1.debian.tar.xz
    .zip does not contain (ref AN11480 4.3):
    When install:
    it asked for libneardal0_<version>_armhf.deb which is not available
  • jomoenginer
    Huh?
    What command line string are you using to get the error?
    Looks like you may have to uncompress the neard-explorenfc_1.2-1.debian.tar.xz and the neard-explorenfc_1.2.orig.tar.gz files further.
    From what I can gather, your command line string should look like:
    sudo dpkg -i libneardal-dev_0.14.3-1_armhf.deb   neard-explorenfc_1.2_armhf.deb
    That is if neard-explorenfc_1.2-1_armhf.deb is in either neard-explorenfc compressed file.
    Also, you need to be in the directory where you unzipped the files when you run the command.
  • ageens
    I know what your saying but i did all that. Untarren etc, files are not available.
  • jomoenginer
    If you are unwilling to provide the exact command line string your are typing to reach this error, then it would be nearly impossible to help you find a solution.
    My recommendation is for you to provide either a screen shot or a copy-paste of the command your are typing and error you are seeing as well as post the output of 'ls' from the directory where you uncompressed the files.
