Single-Board Computers
  • Single-Board Computers
Forum Feedback requested for VisualPRU: Browser-based Editor and Debugger for the BBB PRUs
  • Subscribers 57 subscribers
  • Views 873 views
  • pru
  • beagleboneblack
  • bbb
  • beaglebone-black
Hi All!
I recently made a tool to make programming the BeagleBone Black PRUs a little easier. It's a browser-based editor and debugging tool which is designed to be easier-to-use than the current options. I have a few ideas for next steps(setting breakpoints, modifying memory registers, viewing chunks in DDR RAM, leading pre-built libraries, etc..).
More details and installation instructions are on Github: https://github.com/mmcdan/visualpru
It's still in the early stages. Right now, I'm mainly looking for feedback from PRU users... suggestions for improvements, feature requests, issues you've encountered, or if you'd even use a tool like this.
Thanks!
Michael
    e14 Contributor over 12 years ago in reply to shabaz +2
    Yes! Screenshot and explanation below: - The upper header bar allows you to choose which PRU you are targeting and shows their current status. If you're working on an application where the PRUs collaborate…
    shabaz over 12 years ago in reply to e14 Contributor +1
    This looks nice! I'm excited to try it out, although sadly it may be a few weeks before I can find some time for this. I think fustini will be interested too.
    Hi Michael,
    Thanks for sharing this. Do you have a screenshot of it?
    - The upper header bar allows you to choose which PRU you are targeting and shows their current status. If you're working on an application where the PRUs collaborate, it's possible to trigger a program on one PRU and debug the other PRU as they interact.
    - The green bar shows if you have successfully connected to the the PRUs.
    - Column 1 shows the editor view. You can add as many files as you want and include them in your main program(e.g. for header files and macro definitions).
    - Column 2 shows the compiler view. It essentially shows the output from the TI PASM compiler and allows you to step through your code or run it full-speed.
    - Column 3 shows the memory view. It allows you to look at the values of all the general purpose registers. (Looking into adding Scratchpad, Data, and the Host's RAM as well as the ability to watch registers.)
    This looks nice!
    Hi Michael,
    This is exactly what we need at the moment, I followed all steps and got the PRU connected, load a .p file and click Save&Compile, nothing happens but a flash on screen. The console that runs python script does say COMPILE, waiting to receive. And I have nothing showing on the right side of the web page for compilation output. Any idea?
