Single-Board Computers
  • Single-Board Computers
Forum Help needed for prototype
  • Answers 2 answers
  • Subscribers 56 subscribers
  • Views 569 views
I need a PLC for a prototype that I plan to build with my son. Unfortunately, I don't know my Rasberry Pi's from my Gertboards so please help me to come up with a shopping list to select the best components to do something like this;
The attachment shows a pdf of a schematic for a small demonstrator model without the complication of submersing components in water. The rotary motor represents the ocean swell. The step motor will wind slack line onto a drum when the rotary motor moves between 0 deg - 180 deg. Between 180 deg and 360 deg the step motor will be stopped. This will pull the storage vessel down against the force of the spring which represents buoyancy. The ratchet will hold the storage vessel position against the spring when slack is being wound. Once the spring is extended the ratched is released to allow the storage vessel to return to its start position. In doing so a generator is spun and the LED lights to represent power generation.
With funding this would move onto a larger scale prototype for use in a large wave tank and submersible motors. The system is intended as a large scale wave energy system as shown in this link. Instead of driving a hydrogenerator by the inrush of water power, the storage vessel would spin the generator as it returns to the surface. Scaled Buoyancy Engine 2000m - YouTube
    Former Member over 12 years ago in reply to Former Member +1 suggested
    element14Dave to the rescue
    Did you expect this post to be part of a discussion group?
    0 Former Member over 12 years ago in reply to Former Member
    Yes, I'd be grateful for any help and advice regarding the selection of all the kit and software which will be required for the project.
  • element14Dave
    0 element14Dave over 12 years ago in reply to Former Member
    I have moved this discussion to our Single Board Computer group, there are many choices outside of Raspberry Pi or Gertboard that could be of use... we have some great members in there that I am sure would be happy to help you out.
    thanks for being a member!
    0 Former Member over 12 years ago in reply to element14Dave
    Many thanks
