      • Japan
      • Vietnam
BeagleBoard
  • Single-Board Computers
  • BeagleBoard
BeagleBoard
Blog Beagle bone Black Window 10 Driver Fix
Join BeagleBoard to participate - click to join for free!
  • Author Author: djfraz
  • Date Created: 14 Nov 2016 8:44 PM Date Created
  • Views 8929 views
  • Comments 5 comments
  • drivers
  • problem_solved
  • bbb
djfraz
djfraz
14 Nov 2016
After receiving my first beaglebone black a couple of weeks ago, I was eager to get started playing around with it.
So I followed the instructions, plugged into my PC, opened the BBB as an external drive and opened the getting started page. So far so good, I downloaded the drivers and ran the wizard.
Here is where the problems began, I kept getting an error at the end saying that the wizard was unsuccessful. I keep trying, running as admin, re downloading the drivers, trying to install drivers through device manager; but nothing worked.
So after a lot of expletives and shouting (I had just finished a fifteen hour shift and was already a little annoyed) I got fed up of trying and put the BBB in the drawer to try another day.
I haven't heard of anyone on the community having this problem, but whilst searching online I found a lot of other people who this affected.
I had a look online and found out that window 10 needs drivers to have a Signature to be allowed to install. So I had a look for how to disable this feature, finding a tutorial online at How to Disable Driver Signature Verification on 64-Bit Windows 8 or 10 (So That You Can Install Unsigned Drivers) from How-To-Geek. I won't go into detail here on how to do this but will give a brief overview.
Two options exist for doing this the first permanently disables the requirement for signatures (which I didn't want to do, as I know it is there for security reasons) the second only temporarily disables the function, and that is the way I used.
Basically:
  • Restart computer whilst holding down the shift key
  • Click on "Troubleshoot"
  • Select "Advanced Options"
  • Select "Startup Settings"
  • Press F7
  • Finally click restart
Now you can run the driver installer and that should be you. Happy days image
  • djfraz
    djfraz over 9 years ago in reply to clem57 +1
    I know, but I'm not trying to start an argument on which OS is best. I simply encountered a problem, which may affect other OS as well, and when i found a solution I shared it with the community. As I…
  • clem57
    clem57 over 9 years ago
    Windoze is not my favorite especially 10.
  • djfraz
    I know, but I'm not trying to start an argument on which OS is best. I simply encountered a problem, which may affect other OS as well, and when i found a solution I shared it with the community. As I know if someone else like me gets there first BBB and fails at just installing the drivers, they may just give up completly
  • djfraz
