BoothStache is a version of BeagleStache by jkridner optimized for an expo hall booth at a conference (like The specified item was not found.). Instead of a LCD cape, BoothStache uses the BeagleBone Black's HDMI port to display the webcam feed on an HDTV. An added twist is a big red USB button that the user presses to send a tweet of their stache photo (thanks to Python helper that bonnie555 wrote called BeagleButan). Here's the setup:
And here's a video:
The twitter account it's using: http://twitter.com/boothstache/
I used the following equipment:
USB Camera (Amazon)
USB "Stress" Button (eBay)
USB 2.0 Powered Hub
microHDMI cable
32" HDTV
To install the BoothStache version of BeagleStache, use this github repo:
https://github.com/misterbonnie/stache
For example, to download and install, run these commands:
cd $HOME
git clone git://github.com/misterbonnie/stache
cd stache
make && make install
NOTE: You will need add the specific key values for your Twitter account in the config file (https://github.com/misterbonnie/stache/blob/master/config).
To get the USB button working, use this github repo:
https://github.com/misterbonnie/beaglebutan
These are the install instructions from the readme file:
cd $HOME
opkg update
opkg install python-setuptools
okpg install python-ctypes
git clone http://github.com/walac/pyusb.git
cd pyusb
python setup.py install
You should then be able to run beaglebutan to test pressing the button:
root@beaglebone:~/beaglebutan# lsusb
Bus 001 Device 002: ID 1a40:0201 Terminus Technology Inc. FE 2.1 7-port Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 006: ID 04f3:04a0 Elan Microelectronics Corp.
Bus 001 Device 005: ID 046d:082d Logitech, Inc.
root@beaglebone:~/beaglebutan# python button.py
PRESS BUTAN
tempfile doesn't exist
PRESS BUTAN
PRESS BUTAN
PRESS BUTAN
PRESS BUTAN
You should then start up the beaglestache program by running:
root@beaglebone:~/stache# node ./tweetstache.js
Refer to this gist for an example of the the output on the terminal: https://gist.github.com/pdp7/5527178
Please leave a comment if you have any questions.
TGIF!
Drew
shabaz
Cancel
Vote Up
+1
Vote Down
Sign in to reply
More
Cancel
interested1
in reply to shabaz
Cancel
Vote Up
+1
Vote Down
Sign in to reply
More
Cancel
fustini
in reply to interested1
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
Problemchild
in reply to fustini
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
Comment-
Problemchild
in reply to fustini
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
