BeagleBoard
  • Single-Board Computers
  • BeagleBoard
BeagleBoard
Blog BoothStache: Facial hair fun with BeagleBone Black
Join BeagleBoard to participate - click to join for free!
  • Author Author: fustini
  • Date Created: 31 May 2013 10:49 PM Date Created
  • Views 1300 views
  • python
  • design_west
  • beaglebone_black
  • BeagleBone
  • design_west_2013
  • bb_black
  • beagle_bone_black
fustini
fustini
31 May 2013
BoothStache is a version of BeagleStache by jkridner optimized for an expo hall booth at a conference (like The specified item was not found.).  Instead of a LCD cape, BoothStache uses the BeagleBone Black's HDMI port to display the webcam feed on an HDTV.   An added twist is a big red USB button that the user presses to send a tweet of their stache photo (thanks to Python helper that bonnie555 wrote called BeagleButan).  Here's the setup:
And here's a video:
The twitter account it's using: http://twitter.com/boothstache/
I used the following equipment:
BeagleBone Black
USB Camera (Amazon)
USB "Stress" Button (eBay)
USB 2.0 Powered Hub
microHDMI cable
32" HDTV
To install the BoothStache version of BeagleStache, use this github repo:
https://github.com/misterbonnie/stache
For example, to download and install, run these commands:
cd $HOME
git clone git://github.com/misterbonnie/stache
cd stache
make && make install
NOTE: You will need add the specific key values for your Twitter account in the config file (https://github.com/misterbonnie/stache/blob/master/config).
To get the USB button working, use this github repo:
https://github.com/misterbonnie/beaglebutan
These are the install instructions from the readme file:
cd $HOME
opkg update
opkg install python-setuptools
okpg install python-ctypes
git clone http://github.com/walac/pyusb.git
cd pyusb
python setup.py install
git clone https://github.com/misterbonnie/beaglebutan
You should then be able to run beaglebutan to test pressing the button:
root@beaglebone:~/beaglebutan# lsusb
Bus 001 Device 002: ID 1a40:0201 Terminus Technology Inc. FE 2.1 7-port Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 006: ID 04f3:04a0 Elan Microelectronics Corp.
Bus 001 Device 005: ID 046d:082d Logitech, Inc.
root@beaglebone:~/beaglebutan# python button.py
PRESS BUTAN
tempfile doesn't exist
PRESS BUTAN
PRESS BUTAN
PRESS BUTAN
PRESS BUTAN
You should then start up the beaglestache program by running:
root@beaglebone:~/stache# node ./tweetstache.js
Refer to this gist for an example of the the output on the terminal: https://gist.github.com/pdp7/5527178
Please leave a comment if you have any questions.
TGIF!
Drew
http://twitter.com/pdp7
    shabaz over 12 years ago +1
    Hi Drew, Thanks for sharing. This was a really nice example of different technologies working together to produce this system. I had fun exploring the repository and looking at the code.
  • interested1
    interested1 over 12 years ago in reply to shabaz +1
    Nice work Drew. I tried to get this going with the Camera Cape, but there were some issues related to the memory allocation (the cape was working properly, but the stache application complained and wouldn…
    Hi Drew,
    Hi Drew,
  • interested1
    Nice work Drew.  I tried to get this going with the Camera Cape, but there were some issues related to the memory allocation (the cape was working properly, but the stache application complained and wouldn't work).  Have you had any luck with a non-USB camera setup?
  • fustini
    fustini over 12 years ago in reply to interested1
    Sorry, I've only tried it with USB webcams: Logitech c920 and a PS3 Eye.  What message did the stache executable print?
  • Problemchild
    Problemchild over 12 years ago in reply to fustini
    Drew I thought it was doing some facial anaysis then puting a proper beard on you.
    If that was the case I would of suspected Steroid Abuse on the part of the BBB image
    Very much a fun little project!
