      • Japan
      • Vietnam
BeagleBoard
  • Single-Board Computers
  • BeagleBoard
BeagleBoard
Blog Sketching in Hardware 2013: Physical Computing with JavaScript
Join BeagleBoard to participate - click to join for free!
  • Author Author: fustini
  • Date Created: 31 Jul 2013 4:47 PM Date Created
  • Views 2088 views
  • Comments 8 comments
  • sketching
  • sketcking_in_hardware
  • beaglebone_black
  • sketching13
  • bonescript
  • bbb
  • BeagleBone
  • bb_black
  • beagleboard
  • beagle_bone_black
fustini
fustini
31 Jul 2013
I have attached slides from Jason Kridner's Physical Computing with JavaScript presentation at Sketching in Hardware 2013 (http://sketching-in-hardware.com/).
imageJason Kridner - Physical Computing with JavaScript.pdf
    shabaz over 12 years ago +1
    Great slides! Initially in the past I had been confused, because since Javascript runs on the browser, (and I hadn't heard of Node.js) I was a little confused and had thought that I'd need a browser opened…
  • fustini
    fustini over 12 years ago in reply to shabaz +1
    Jason told me he hopes in to add UART, SPI and I2C over the next few release so that Bonescript will be fully featured. Interesting post recently from the TinyG guys: https://plus.google.com/102479037893713042691…
  • fustini
    fustini over 12 years ago in reply to fustini +1
    https://github.com/giseburt/TinyG-node
    Great slides!
    Initially in the past I had been confused, because since Javascript runs on the browser, (and I hadn't heard of Node.js) I was a little confused and had thought that I'd need a browser opened on the BBB to make use of bonescript, so I'd ignored it all.
    Now it's much clearer that this is the Javascript engine, but doesn't need a browser to run in. It's very cool, since Javascript is a fairly friendly language (in the past, for what little I've done, I've relied on javascript libraries heavily to make sure that it works consistently across browsers, but I'm sure that has changed now - or at least is a non-issue in this case, since there is only one Node.js engine).
    It's also extremely powerful  that you can use other existing js libraries! That sounds pretty amazing. I can't wait to try that out. And create http based UIs without needing Apache and PHP.
    Possibly this can all be done with Python too (I don't know) but I'm convinced js+bonescript is worth paying a lot of attention to, to rapidly develop applications - and in a language that is literally designed for the web, so lots of knowledge reuse for those who will one day want to create web apps.
    The ideal scenario for some apps could be PRU<->C/C++ and then IPC with Node.js javascript (and bonescript for any direct hw control) for the http based UI.
    Also, I wonder how performance compares with a typical desktop browser running JS.
  • fustini
    https://plus.google.com/102479037893713042691/posts/NrEVc1ryLWB
    One beaglebone to program our TinyG, One beaglebone to test our TinyG and in the darkness bind them.. Well not the last part.  However +Rob Giseburt  wrote the nodeJS that does all the magics on the software. +Alden Hart  did the hardware design and I did the enclosure setup.
  • fustini
    shabaz over 12 years ago in reply to fustini
    Very nice. Thanks! There was a simple example of the node.js program serving a web page and socket.io comms to it in a subfolder here, so that's a good starting point to developing a UI portion for applications.
    The screenshot below was from their flickr page, the code is not checked-in I guess currently (I couldn't see it at that github) but the screenshot provides some ideas. Very neat that all their control to the hardware was via bonescript, so no need for any C/C++ code in their particular case.
  • morgaine
    morgaine over 12 years ago in reply to fustini
    As a result of 3D printing, blue tape may be taking over from duck/gaffer tape in the geek Tape-All-The-Things meme! image
  • morgaine
