BeagleBoard
  • Single-Board Computers
  • BeagleBoard
BeagleBoard
Forum Network security key for BeagleBone Black Wireless
Join BeagleBoard to participate - click to join for free!
  • Replies 12 replies
  • Answers 2 answers
  • Subscribers 106 subscribers
  • Views 2892 views
  • frontpage
henryhnguyen2000
henryhnguyen2000 over 9 years ago
Hi All,
I just bought the "BeagleBone Black Wireless", connect the power. It comes up as a secured Access Point with SSID "BeagleBone-XXXX". How do I get the Network Security Key? I check the label on the board "BWAXXXXXBBWGYYYY", And use BWAXXXXX or BBWGYYYY as keys, but it does not work. I read through a bunch of documents and can not find the key any where. Your help is appreciated.
Henry Nguyen
  • bwelsby
    bwelsby over 9 years ago +1 verified
    Henry Nguyen wrote: Hi All, I just bought the "BeagleBone Black Wireless", connect the power. It comes up as a secured Access Point with SSID "BeagleBone-XXXX". How do I get the Network Security Key? I…
  • bwelsby
    bwelsby over 9 years ago +1 suggested
    If you want to change the password (good idea) then have a look in /var/lib/connman/settings for tethering.passphrase Brian
  • bwelsby
    bwelsby over 9 years ago in reply to henryhnguyen2000 +1 suggested
    Henry Nguyen wrote: Hi Brian, As the BeagleBone Black Wireless board wireless default mode is set to Access Point, how do I set it to wireless station (Type: Managed or Infrastructure), I try to use the…
  • bwelsby
    0 bwelsby over 9 years ago
    Henry Nguyen wrote:
    Hi All,
    Henry Nguyen
    I think you will find it is set to   BeagleBone
    Brian
  • bwelsby
    Brian
  • henryhnguyen2000
    0 henryhnguyen2000 over 9 years ago in reply to bwelsby
    Hi Brian,
    Thanks. It works. The funny thing is when I click on connect, Windows 10 asks for the PIN number of the router??? I have to switch to enter security key, then I enter BeagleBone.
    Henry Nguyen
  • henryhnguyen2000
    Hi Brian,
    As the BeagleBone Black Wireless board wireless default mode is set to Access Point,  how do I set it to wireless station (Type: Managed or Infrastructure), I try to use the iw command as:
    iw set type managed
    I got an error:
    command failed: Device or resource busy (-16)
    Please advice.
    Henry Nguyen
  • bwelsby
    0 bwelsby over 9 years ago in reply to henryhnguyen2000
    Henry Nguyen wrote:
    Hi Brian,
    iw set type managed
    I got an error:
    Please advice.
    Henry Nguyen
    Yeah, the latest Debian releases have changed how the WiFi is configured. You have to use connmanctl   as root ( sudo -s)
    Here's a link for how it's done on the BBE but should be the same for any Beaglebone with WiFi  running the latest Debian  WiFi AP mode Enable/Disable – SanCloud
    Brian
  • henryhnguyen2000
    Hi Brian,
    It works.
    Thanks a lot,
    Henry Nguyen
  • bwelsby
    Thanks a lot,
    Henry Nguyen
    You're welcome.
    Brian
  • henryhnguyen2000
    Hi Brian,
    Now I try to switch back to the AP mode using:
    root@beaglebone:~# sudo -s connmanctl
    Error getting VPN connections: The name net.connman.vpn was not provided by any
    connmanctl> tether wifi enable
    Error enabling wifi tethering: Permission denied
    Note that I already use: disable wifi. I even logout and login as root. Any idea?
    Henry Nguyen
  • henryhnguyen2000
    0 henryhnguyen2000 over 9 years ago in reply to henryhnguyen2000
    Hi Brian,
    It works now???  I type:
    root@beaglebone:~# connmanctl
    connmanctl> agent off
    Agent not registered
    Enabled tethering for wifi
    connmanctl> quit
    I guess it does not like sudo???
    Henry Nguyen
  • bwelsby
    Sorry I may have caused confusion,  If you are logged in as a user such as debian then sudo lets you run a command as root If you are already logged in as root then of course you don't need it.
    As for the errors .. strange,   dunno why they happened but you got it sorted.
    Brian
