BeagleBoard
  • Single-Board Computers
  • BeagleBoard
BeagleBoard
Forum Get zero for clock_gettime(CLOCK_PROCESS_CPUTIME_ID, &start);
Join BeagleBoard to participate - click to join for free!
  • Subscribers 101 subscribers
  • Views 782 views
  • bbb
chrischristian14
chrischristian14 over 6 years ago
I am using clock_gettime(CLOCK_PROCESS_CPUTIME_ID, &start); function in my code on Ubuntu and it gives me correct time but the same code compiled for Pocketbeagle returns 0.
Any ideas ? I am making a PID controller and I need to know "last time" for I and D calculations.
    shabaz over 6 years ago in reply to chrischristian14 +2 verified
    Hi Chris, I've not tried it on BBB or PB, but I've used this code in the past on other machines.. not saying it is great code, but it worked at the time: #include <stdlib.h> #include <time.h> struct timespec…
  • chrischristian14
    0 chrischristian14 over 6 years ago
    Ok, I think that was a very poor explanation, please see the below code for the PID I am using , I get zero for millis() function on pocketbeagle
    #include <stdio.h>
    #include <time.h>
    #include <unistd.h>
    /*working variables*/
    unsigned long lastTime;
    double Input, Output, Setpoint; // Setpoint = desired pressure, Ouput is PWM value, Input is measured current value
    double errSum, lastErr;
    double kp, ki, kd;
    struct timespec start, stop;
    double millis()
    double result = (stop.tv_sec - start.tv_sec) * 1e6 + (stop.tv_nsec - start.tv_nsec) / 1e3;    // in microseconds
    return result;
    void Compute()
       /*How long since we last calculated*/
       unsigned long now = millis();
       double timeChange = (double)(now - lastTime);
       printf("now is : %lu\n",now);
       printf("time change is : %f\n",timeChange);
       /*Compute all the working error variables*/
       double error = Setpoint - Input;  // Proportional error
       errSum += (error * timeChange); // Integral error
       double dErr = (error - lastErr) / timeChange; // Differential error
       /*Compute PID Output*/
       Output = kp * error + ki * errSum + kd * dErr;
       /*Remember some variables for next time*/
       lastErr = error;
       lastTime = now;
    void SetTunings(double Kp, double Ki, double Kd)
       kp = Kp;
       ki = Ki;
       kd = Kd;
    int main()
    printf("time diff is : %f\n",millis());
    while(1)
    sleep(3);
    Compute();
    sleep(3);
    return 0;
    0 shabaz over 6 years ago in reply to chrischristian14
    Hi Chris,
    #include <stdlib.h>
    #include <time.h>
    struct timespec ts_zero;
    void
    get_tzero(void)
      clock_gettime(CLOCK_MONOTONIC, &ts_zero);
    long
    get_time(void)
      long nsec, sec;
      struct timespec tts;
      clock_gettime(CLOCK_MONOTONIC, &tts);
      sec=tts.tv_sec-ts_zero.tv_sec;
      nsec=tts.tv_nsec-ts_zero.tv_nsec;
      if (sec>0)
        nsec=nsec+1E9; // we don't expect times greater than 1 sec
      ts_zero=tts;
      return(nsec);
    in your code:
    execute get_tzero() at the start of the event that you wish to time
    At the end of the event, use:
    long nsec;
    nsec=get_time();
    nsec will contain the duration of the event in nanosec.
