WaRP7
  • Single-Board Computers
  • WaRP7
WaRP7
Forum Linux DTB support to run Cortex A7 and Cortex M4 simultaneously on WaRP 7
Join WaRP7 to participate - click to join for free!
  • Replies 14 replies
  • Subscribers 10 subscribers
  • Views 3569 views
  • warp
  • nxp-warp7
vnr1992
vnr1992 over 9 years ago
Hi All,
On WaRP 7 board, I am trying to run Linux on Cortex A7 and RTOS based binary on Cortex M4.
I need to run both of these cores simultaneously.
While doing this, I followed below steps...
1) Run U-boot on A7
2) Load M4 binary in TCM attached to M4 using fatload command on Uboot.
3) Run M4 core by bootaux <image addr>
       (At this stage M4 binary is successfully executed.)
4) run bootcmd on Uboot console to run Linux image.
       At this stage, I am not able to run linux image and kernel is not be able to boot.
I looked in support for other NXP based boards. They are providing support for separate linux device tree blob (dtb) for this purpose with which it let M4 run simultaneous binary.
Does anyone aware about this kind support for WaRP7 board?
Thank you for your help in advance.
Vivek
  • griff0417
    griff0417 over 9 years ago +1
    I seem to be having a similar issue. I got FreeRTOS from https://github.com/WaRP7/FreeRTOS_WaRP7 and was able to build and boot the hello_world example on the M4 without any issues. However, after booting…
  • tusharp
    0 tusharp over 9 years ago
    As already replied in your other thread, we are coming up with the support by Nov.
  • griff0417
    0 griff0417 over 9 years ago
    I seem to be having a similar issue. I got FreeRTOS from https://github.com/WaRP7/FreeRTOS_WaRP7 and was able to build and boot the hello_world example on the M4 without any issues. However, after booting with bootaux, I try to boot Linux on the A7 ('run bootcmd' from uboot prompt) and it hangs at Starting Kernel...
    Is running the A7 and M4 simultaneously currently supported?
  • griff0417
    I was able to get this working by adding imx7d-sdb-m4.dtb to KERNEL_DEVICETREE of the imx7s-warp.conf in source/meta-fsl-arm-extra/conf/machine
    KERNEL_DEVICETREE = "imx7s-warp.dtb imx7d-sdb-m4.dtb"
  • hanooi
    0 hanooi over 9 years ago in reply to griff0417
    Good to know.  What compiler are you running to program the board?  I'm also using the Warp7 reference for a commercial design.  It looks like support is very spotty so maybe we should collaborate and help each other out.
  • griff0417
    0 griff0417 over 9 years ago in reply to hanooi
    We are using gcc and g++ to compile freertos. I was able to setup eclipse (KDS) with some minor tweaking to this guide. I was able to get it working by adding __FPU_PRESENT=1 and ARM_MATH_M4 to the preprocessor defined symbols in eclipse. Then I just take the bin and copy to the fat partition containing the *.dtb's, zimage, etc and place it here. Here is our uboot variables which I copy and paste in manually at the moment for the M4.
    setenv m4image 'hello_world.bin'
    setenv m4loadaddr '0x7F8000'
    setenv loadm4image 'fatload mmc ${mmcdev}:${mmcpart} ${m4loadaddr} ${m4image}'
    setenv m4boot 'run loadm4image; dcache flush; bootaux ${m4loadaddr}'
    saveenv
    run m4boot
    run bootcmd
    If you would like uboot to boot the M4 auto then just add:
         setenv bootcmd 'run m4boot; '${bootcmd}
    Save changes (type printenv to see changes):
         saveenv
  • griff0417
    0 griff0417 over 9 years ago in reply to griff0417
    You could also add the below line to <BUILD_DIR>/conf/local.conf if you are using yocto:
    KERNEL_DEVICETREE_append =" imx7d-sdb-m4.dtb"
  • texierp
    0 texierp over 8 years ago
    Hi All,
    Just for your information, all the support for A7/M4 is now ok with the meta-warp7-distro (https://github.com/WaRP7/meta-warp7-distro/commit/ff8a2cfe7d902b1ed2155d1c28e82f2b99414b8c#diff-dfb22962245d7f5ae492b643… )
    Do not hesitate to contact me if you have any questions image
    Pierre-Jean
  • hanooi
    0 hanooi over 8 years ago in reply to texierp
    Would it work with Debian Linux?  My customized Warp7 board now uses Debian.
  • texierp
    0 texierp over 8 years ago in reply to hanooi
    I think, you just have to update your zImage to support RPMsg, see the following patches:
    - https://github.com/WaRP7/meta-warp7-distro/blob/master/recipes-kernel/linux/linux-warp7/imx7s-warp/ARM-imx-Add-imx7s-war…
    - https://github.com/WaRP7/meta-warp7-distro/blob/master/recipes-kernel/linux/linux-warp7/imx7s-warp/0005-Add-m4-support-a…
    - https://github.com/WaRP7/meta-warp7-distro/blob/master/recipes-kernel/linux/linux-warp7/imx7s-warp/0004-Add-m4-support.p…
    Pierre-Jean
  • mhanuel
    0 mhanuel over 8 years ago in reply to hanooi
    Hello hanooi,
    I am looking to have debian on imx7, would you give me some advice of how it can be done using yocto? I know of a meta-debian layer but last time I document myself there was no bsp for imx7.
    I will appreciate your comments,
