    Members
    • Avnet Boards Community
    • Choose Another Store
Technical Library
  • Technical Library
Technical Library
Forum Data sheet drawings
Technical Library requires membership for participation - click to join
  • Subscribers 46 subscribers
  • Views 133 views
  • Datasheet
Data sheet drawings
Former Member over 7 years ago
I've noticed on some data sheet drawings that the projection angle isn't given. Is there any way to contact Multicomp?
I don't seem to be able to find anything on them.
Cheers
Dave
  • Reply
  • clem57
    0 clem57 over 7 years ago
    Can you give some examples?
    • Up 0 Down
    • Reply
    0 shabaz over 7 years ago
    Usually it is clear from context (and often the different projections are not laid out as expected on a tech drawing, probably for clarity on an A4 or letter sized page and instead just in a vertical arrangement for all views)  but otherwise third angle is always presumed. Not sure I've seen a first angle projection in >10 years. But to be 100% sure I often wait till I have the part in my hand.
    • Up 0 Down
    • Reply
    0 Former Member over 7 years ago
    It was particularly with the Peltier element I'm working with (part number 1639732). I ended giving it a bit of controlled power to sort it out. After a bit of googling it turns out that the diagram is in fact 1st Angle projection (left side view to the right).
    Like you Shabaz I usually tend to the 3rd angle but I've been caught out with Peltier drawings before
    Seems silly that the batch number can be printed on the element but why not a hot or cold symbol.
    Cheers
    Dave
    • Up 0 Down
    • Reply
Element14
An Avnet Company © 2022 Premier Farnell Limited. All Rights Reserved.
  • Twitter
