    Members
    • Avnet Boards Community
    • Choose Another Store
Technical Library
  • Technical Library
Technical Library
Forum ADF7021 (error)
Technical Library requires membership for participation - click to join
  • Replies 11 replies
  • Subscribers 46 subscribers
  • Views 239 views
ADF7021 (error)
Former Member over 6 years ago
Dear all,
Help me!
I bought 2 EVAL-kit ADF7021-N from Digikey.
I use UART mode and make 435 Mhz for communications.
I can see RF signal ( 435Mhz) in the spectrum analyzer with transmit mode.
But, in receive mode, i got the problem.
there is always a continueous pusle in pin TxRx DATA ( pin 34).
Anybody can help me, please!
many thanks
  • Reply
  • clem57
    clem57 over 6 years ago
    http://www.analog.com/media/en/technical-documentation/data-sheets/ADF7021-N.pdf Have you read?
    Where are you located? This freq is used by UHF and other things and is not allowed in the US.
    Clem
    • Up 0 Down
    • Reply
    Former Member over 6 years ago in reply to clem57
    Dear Clem Martins,
    Thank you so much for your reply!
    - I read datasheets many times, many times.
    - I am in Viet Nam. This is a test in Lab. I can adjust frequency into VHF, UHF by my software.
    I have a problem with receive mode!
    Can you help me, please?
    Many thanks,
    NA
    • Up 0 Down
    • Reply
  • clem57
    clem57 over 6 years ago in reply to Former Member
    Have you tried other frequencies? Make sure the bandwidth are the same on both sides. Also is there other devices in the lab at the same frequency?
    • Up 0 Down
    • Reply
  • clem57
    Read ADF7021 for some more considerations.
    • Up 0 Down
    • Reply
    yes, I tried some other frequencies.
    yes, same bandwidth
    yes, I am very sure because I have a spectrum analyzer.
    I did this many times. I also donwloaded codes from the internet with reference.
    finally, same results. There is STILL  a pulse ( frequency from 150hz - 250hz , I see on the Ossiloscope) in pin TxRxDATA ( pin 34). And, when I turned off the transmit kit, there is still that pulse in receive kit ( at in 34).
    I don't understand why, Clem Martins.
    NA
    • Up 0 Down
    • Reply
  • clem57
    So you have this setup:
    Note that Mcu TxDATA goes to TxRxCLK and RxDATA goes to TxRxDATA.
    Clem
    • Up 0 Down
    • Reply
    I researched the topic ADF7021 for some more considerations.
    yes, in transmit kit, I push data in TxRxCLK. And in receive kit, I should get data in TxRxData ( 34 pin). But, there is ALWAYS a pulse at this pin.
    I think that trasmit mode is okay.
    there is a problem in receive mode that makes a pulse at pin 34.
    • Up 0 Down
    • Reply
    • Up 0 Down
    • Reply
  • clem57
    I am turning in since very late here. But you may want to try https://ez.analog.com/welcome
    for their blogs.
    Clem
    • Up 0 Down
    • Reply
    They will say:
    " I’m sorry. Questions on ISM and Licensed Band Transceivers (products with ADF7XXX part numbers) are not  handled on Engineerzone and should be directed to your local sales organization"
    • Up 0 Down
    • Reply
Element14
An Avnet Company © 2022 Premier Farnell Limited. All Rights Reserved.
  • Twitter
