Technical Library
  • Technical Library
Technical Library
Documents Analog Devices: CN0206 Refernce Design for Complete Type Thermocouple Measurement System
  • Author Author: atomar
  • Date Created: 11 Mar 2013 12:34 PM Date Created
  • Last Updated Last Updated: 23 Apr 2013 5:56 AM
  • Views 2687 views
BUY NOWBUY NOWDevelopment ToolsTechnical DocumentsVideoFeaturesKit Contents
Kit Overview
The Analog Devices EVAL-CN0206-SDPZEVAL-CN0206-SDPZ circuit  is a complete thermocouple system based on the AD7793AD7793 24-bit sigma-delta (Σ-Δ) analog-to-digital converter (ADC). The AD7793 is a low power, low noise, complete analog front end for high precision measurement applications. The device includes a programmable gain amplifier (PGA), an internal reference, an internal clock, and excitation currents, thereby greatly simplifying the thermocouple system design.
The AD7793AD7793 consumes only 500 μA maximum, making it suitable for any low power application, such as smart transmitters where the complete transmitter must consume less than 4 mA. The AD7793 has a power-down option. In this mode, the complete ADC, along with its auxiliary functions, is powered down so that the part consumes 1 μA maximum.
Because the AD7793AD7793 provides an integrated solution for thermocouple design, it interfaces directly to the thermocouple. For the cold junction compensation, a thermistor along with a precision resistor is used. These are the only external components required for the cold junction measurement other than some simple RC filters for EMC considerations.
This circuit uses the EVAL-CN0206-SDPZEVAL-CN0206-SDPZ circuit board and the http://www.analog.com/en/system-demonstration-platform/controller-boards/evaluation/SDP-B/eb.htmlEVAL-SDP-CB1ZEVAL-SDP-CB1Z System Demonstration Platform (SDP-B) evaluation board. The two boards have 120-pin mating connectors, allowing for the quick setup and evaluation of the circuit’s performance. The EVAL-CN0206-SDPZEVAL-CN0206-SDPZ board contains the circuit to be evaluated, and the SDP evaluation board is used with the  CN0206 Evaluation Software to capture the data from the EVAL-CN0206-SDPZEVAL-CN0206-SDPZ circuit board
Key Applications: Field Instruments/ Smart Transmitters, High Temperature, Temperature Controllers
imageMore Analog Devices Analog Development KitsimageAnalog Devices MCU based Development Kits
Development Tools
  • A PC with a USB port and WindowsRegistered XP and Windows VistaRegistered (32-bit), or WindowsRegistered 7 (32-bit)
  • The EVAL-CN0206-SDPZEVAL-CN0206-SDPZ circuit evaluation board
  • The EVAL-SDP-CB1ZEVAL-SDP-CB1Z SDP evaluation board
    • Blackfin Processor ADSP-BF527
    • USB 2.0 Interface to PC
    • JTAG header footprint
    • 32MB SDRAM
    • 2 x Small Footprint 120 Pin Connectors
    • Configurable Peripheral Interfaces - SPI - SPORT - I2C - GPIOs - Parallel - Timers
  • The CN0206 Evaluation Software
  • A power supply: 6 V or 6 V wall wart (EVAL-CFTL-6V-PWRZEVAL-CFTL-6V-PWRZ)
  • The CL540ZA thermocouple source or alternate
Back to top
Technical Documents
Learning Center
TypeDescription
User GuideADI: User Guide (UG-181) for PLC Demo System
User ManualADI: User Manual for CN-0206 Complete Thermocouple Measurement System Using the AD7793 24-Bit Sigma-Delta ADC
DatasheetADI: Datasheet for AD7792/AD7793: 3-Channel, Low Noise, Low Power, 16-/24-Bit Sigma Delta ADC with On-Chip In-Amp and Reference (Rev B)
DatasheetADI: Datasheet for ADP3336:High Accuracy Ultralow IQ, 500 mA anyCAP Adjustable Low Dropout Regulator (Rev A)
Design Elements
TypeDescription
SchematicsADI: Schematics for EVAL-CN0206-SDPZ Evaluation Board
LayoutADI: Layout for EVAL-CN0206-SDPZ
BOMADI: Bill of Material (BOM) for EVAL-CN0206-SDPZ Evaluation Board
Application LibraryADI: Software Code for AD7793 - Microcontroller No-OS Driver
Back to top
Video
Back to top
Kit Features
Key Feature for AD7793AD7793 are as below:
  • Up to 23 bits effective resolution
  • RMS noise
    • 40 nV @ 4.17 Hz
    • 85 nV @ 16.7 Hz
  • Current: 400 μA typical
  • Power-down: 1 μA maximum
  • Low noise programmable gain instrumentation amp
  • Band gap reference with 4 ppm/°C drift typical
  • Update rate: 4.17 Hz to 470 Hz
  • 3 differential inputs
  • Internal clock oscillator
  • Simultaneous 50 Hz/60 Hz rejection
  • Programmable current sources
  • On-chip bias voltage generator
  • Burnout currents
  • Power supply: 2.7 V to 5.25 V
  • Interface
    • 3-wire serial
    • SPIRegistered, QSPITm, MICROWIRETm, and DSP compatible
    • Schmitt trigger on SCLK
Back to top
Kit Contents
The Analog Devices EVAL-CN0206-SDPZEVAL-CN0206-SDPZ is supplied with below contents:
  • Evaluation Board
Back to top
  • ad7793
  • eval-cn0206-sdpz
  • analog_devices
