    • Avnet Boards Community
EAGLE User Chat (English) Filtering ratsnest by component
  • Subscribers 170 subscribers
  • Views 240 views
Hey,
I recently purchaced Eagle standard and am currently laying out a few pcbs. Is there any way to filter the ratsnest by component? Or at least by layer? It becomes a giant mess with multiple layers of airwires all crossing one another, I can almost feel the myopia developing already. Any help would be greatly appreciated!
    On 27.09.2013 00:44, J S wrote:
    Hey,
    http://www.element14.com/community/message/90032#90032
    You can filter it by signals. From HELP RATSNEST:
    Hiding selected airwires
    Sometimes it may be useful to hide the airwires of selected signals, for
    instance if these will later be connected through a polygon. Typically
    this could be supply signals, which have a lot of airwires that will
    never be routed explicitly and just obscure the other signals' airwires.
    To hide airwires the RATSNEST command can be given the exclamation mark
    ('!'), followed by a list of signals, as in
    RATSNEST ! GND VCC
    which would hide the airwires of the signals GND and VCC.
    To have the airwires displayed again just enter the RATSNEST command
    without the '!' character, and the list of signals:
    RATSNEST GND VCC
    This will activate the display of the airwires of the signals GND and
    VCC and also recalculates them. You can also recalculate the airwires
    (and polygons) of particular signals this way.
    The signal names may contain wildcards, and the two variants may be
    combined, as in
    RATSNEST D* ! ?GND VCC
    which would recalculate and display the airwires of all signals with
    names beginning with 'D', and hide the airwires of all the various GND
    signals (like AGND, DGND etc.) and the VCC signal. Note that the command
    is processed from left to right, so in case there is a DGND signal the
    example would first process it for display, but then hide its airwires.
    To make sure all airwires are displayed enter
    RATSNEST *
    Note that the SIGNAL command will automatically make the airwires of a
    signal visible if a new airwire is created for that signal. The RIPUP
    command on the other hand will not change the state of hiding airwires
    if a wire of a signal is changed into an airwire.
    Richard Hammerl
