    • Avnet Boards Community
EAGLE User Chat (English) vacuum tube socket base ?
Autodesk EAGLE requires membership for participation - click to join
  • Replies 7 replies
  • Subscribers 173 subscribers
  • Views 1468 views
Former Member over 16 years ago
Hi I'm working on a simple Vacuum tube AKA Valve guitar amp circuit.
Is there a library that has vacuum tube socket bases for 9 pin?
Glen
  • Richard_H
    Richard_H over 16 years ago
    Glen
    Try nixie_tube.lbr, russian-nixies.lbr or tubes.lbr in the Download
    area.
    Richard Hammerl
  • nickds1
    nickds1 over 16 years ago
    "Richard Hammerl" <ric@cadsoft.de> wrote in message
    news:gm8pi1$mub$1@cheetah.cadsoft.de...
    Glen
    area.
    I have an Eagle tube socket script generator at
    http://www.desmith.com/NMdS/Electronics/soculator.html
    HTH
    Nick
    Thanks guys both those suggestions are great!!
    Glen
    "Glen Higgs" <ghiggs@rogers.com> wrote in message
    news:gm89o9$5gs$1@cheetah.cadsoft.de...
    Glen
    Former Member over 16 years ago in reply to nickds1
    Hi Nick
    I got around to using the link you posted and made my socket and put it in a
    library.
    My question is, I'm only able to use the socket in the board editor. The
    socket does not show up in the schematic.
    Is there a way to be able to have the socket show up in the schematic?
    Glen
    "Nick de Smith" <nick@desmith.net> wrote in message
    news:gm90uv$jil$1@cheetah.cadsoft.de...
    Glen
    area.
    HTH
    Nick
    Glen Higgs schrieb:
    Hi Nick
    in a library.
    Glen
    A symbol for the schematic has little to do with the realtity of a
    board. Just place a few connectors symbols and combine that to a device.
    Gruß / regards
    Jörn
    Glen Higgs schreef:
    Hi Nick
    in a library.
    Glen
    Glen
    area.
    HTH
    Nick
      Hi Glen,
    Your socket (the package) is not enough to create a complete library
    sysmbol. You also need a symbol for the schematic. You can download
    'TUBES.ZIP'  (by Mühlke Thorsten) from the Cadsoft website and 'borrow'
    a symbol from there (ie. diode, triode, pentode). After that you connect
    the symbol (schematic) and the package (board) into a device. (using the
    library editor)
    If you don't know how to do this, maybe now is a good time to download
    the Eagle tutorial from the same location...
    Good luck,
    Richard
    Thanks Richard for taking the time to explain it properly!
    I'll give it a try.
    Glen
    "Richard Herman" <postbus@het-audio-team.removethis.nl> wrote in message
    news:gq0jmi$1db$1@cheetah.cadsoft.de...
    Glen Higgs schreef:
    Hi Nick
    in a library.
    Glen
    Glen
    area.
    HTH
    Nick
    Hi Glen,
    'TUBES.ZIP'  (by Mühlke Thorsten) from the Cadsoft website and 'borrow' a
    symbol from there (ie. diode, triode, pentode). After that you connect the
    library editor)
    If you don't know how to do this, maybe now is a good time to download the
    Good luck,
    Richard
