EAGLE User Chat (English) Do you know a cheap hobby CNC PCB router for that just handles the small PCB sizes of the free EagleCAD?
  • Replies 7 replies
  • Subscribers 187 subscribers
  • Views 915 views
I would like to know if someone has good experience with a very cheap
small CNC router that can be used for PCB prototyping.
There is some information here:
http://www.cnczone.com/forums/showthread.php?t=16899
but I can't find a machine as small (read cheap) as I would think is
possible to find.
Anyone?
    autodeskguest over 16 years ago in reply to autodeskguest
    Hi Guys,
    Comments in line.
    creid wrote:
    They might be overpriced, but I don't understand why that is the
    case. Why is there not a single one that I can find on google that is
    in the price range you mention ($100-$300). They are about 10 times
    more expensive, and all I wanted was to play with small double sided
    PCBs around the size of EagleCads free version: small.
    Because they can. You'd be shocked at the garbage they sell to machine
    hobbyists with the same kind of markup.
    For 3 times the cost of my cnc mill you can get a cheap JUNK cnc hobby
    mill.. that happened to have been the #1 seller for a decade or so..
    that is inferior in literally every category.
    A bit harsh ! But I do agree that there is a lot of junk purveyed.
    Some of the ex school machines of the BBC era are very good and still
    kicking about. (Note: reference to UK schools)
    If you want to do really small.. build your own. Im going to give you
    a crash course.
    The single most important thing on a cnc mill of any kind are the
    ballscrews. Those are literally screws.. with nuts on them. The trick
    is they have no backlash (wiggle.. sloppiness). There are ways to make
    some acceptable.. for instance if you have a mill... but better just
    to buy them. For the lengths you're talking about your talking 20, 30,
    50 bucks. You also need ''ways". Think of it as tracks. That can get a
    lil complex but Gantry mills bypass all that by just using round rods.
    Look up "drill rod". For the size you need you're talking like.. 5
    bucks. It is dimensionally accurate hardenable steel. You THINK you've
    seen round stuff..
    The cheapest source for these rods is a scrap inkjet printer ! and you
    will get a pair of guides thrown in.
    What you do for the x and y axes is mount two
    perfectly parallel pieces of drill rod. Mount your motor on those
    (different mechanisms for each axis). Perfectly machined holes in say
    1/2" or more 6061 aluminum (you can buy that/have it done).
    I've used "V" blocks to support the guide rods. It makes adjustment
    easier.
    Voila the things cant get out of alignment. You move them via toothed
    belts around pulleys made for them. Say 8 bucks an axis. Zero
    backlash.
    Again these components can be salvaged from scrap printers along with
    the stepper motors and drivers.  The best ones can be found in old
    impact printers, particularly the "Mannesman" machines.
    For the z axis (up/down) you can use a lot of different designs.
    You need a stepper controller board. Most expensive part. Build
    yourself a bipolar chopper driver.. make that 3. Or buy one from
    xylotex,gecko wherever. $150 from xylotex. $50ish you build it
    yourself (or less). If you only want to do like.. 3"x3" boards you
    could get even cheaper and fit the whole deal in a 12x12x12 enclosure
    that fits on your desk. Make a mount for a dremel or.. god forbid a
    GOOD spindle and there ya go. Hook it up to a computer via a Parallel
    line and your'e set to go.
    The cutting head motor for the best accuracy is probably the hardest
    part.  You need to have quite a high spindle speed and a shaft that
    will take a collet chuck.  Finding a suitable motor with minimal side
    play won't be easy or cheap.
    The end play can be controlled with a thrust pad on the other end of the
    spindle. I used a single ball from a ball race and a carbon brush on my
    motor.
    Honestly this would be a good project for you anyway if you're a
    hobbyist. Learn about hbridges, steppers, mosfets and the like. Look
    on google. I have some designs on a yahoo group i made but i forgot
    the group. One was actually mostly made of concrete heh. Look up CNC
    on yahoo groups. Oh.. and look up "GINGERY".
    You can do it man!
    Interesting thread !  I hope that my comments are useful.
    Best Regards:
                         Baron.
    autodeskguest over 17 years ago in reply to autodeskguest
    They might be overpriced, but I don't understand why that is the case. Why
    is there not a single one that I can find on google that is in the price
    range you mention ($100-$300). They are about 10 times more expensive, and
    all I wanted was to play with small double sided PCBs around the size of
    Because they can. Youd be shocked at the garbage they sell to machine
    mill.. that happened to have been the #1 seller for a decade or so.. that is
    If you want to do really small.. build your own. Im going to give you a
    crash course.
    ballscrews. Those are literally screws.. with nuts on them. The trick is
    they have no backlash (wiggle.. sloppiness). There are ways to make some
    acceptable.. for instance if you have a mill... but bettr just to buy them.
    For the lengths you're talking about your talking 20, 30, 50 bucks. You also
    need ''ways". Think of it as tracks. That can get a lil complex but Gantry
    mills bypass all that by just using round rods. Look up "drill rod". For the
    size you need you're talking like.. 5 bucks. It is dimensionally accurate
    hardenable steel. You THINK you've seen round stuff..
    What you do for the x and y axes is mount two perfectly parallel pieces of
    drill rod. Mount your motor on those (different mechanisms for each axis).
    Perfectly machined holes in say 1/2" or more 6061 aluminum (you can buy
    that/have it done). Voila the things cant get out of alignment. You move
    them via toothed belts around pulleys made for them. Say 8 bucks an axis.
    Zero backlash.
    You need a stepper controller board. Most expensive part. Build yourself a
    bipolar chopper driver.. make that 3. Or buy one from xylotex,gecko
    wherever. $150 from xylotex. $50ish you build it yourself (or less). If you
    only want to do like.. 3"x3" boards you could get even cheaper and fit the
    whole deal in a 12x12x12 enclosure that fits on your desk. Make a mount for
    a dremel or.. god forbid a GOOD spindle and there ya go. Hook it up to a
    computer via a Parallel line and your'e set to go.
    Honestly this would be a good project for you anyway if you're a hobbyist.
    Learn about hbridges, steppers, mosfets and the like. Look on google. I have
    some designs on a yahoo group i made but i forgot the group. One was
    actually mostly made of concrete heh. Look up CNC on yahoo groups. Oh.. and
    look up "GINGERY".
    You can do it man!
    creid wrote:
    This may or may not help. You're talking money and theyre
    MASSIVELYoverpriced. The cheapest i think you'll get away with is $1200..
    for cheap plastic garbage. I have a cnc minimill in my garage. All total it
    cost me about $500 to build. It will machine quite literally - anything.
    Titanium, aluminum, steel.. and yes, circuitboards.
    You can build your own for .. well nearly free. If you only want it for cnc
    routing you can build a simple enclosed desktop mill that is the size of a
    printer. You need a 2axis board, two steppers (hefty ones not printer
    steppers). The steppers will cost you $30 to $50 each. If you buy a High
    quality board like Gecko or xylotex  the board will cost you $150 to $250
    though you could build your own. PCB's dont require anything close to the
    accuracy machining does (.001" or more). For a z axis a solenoid would work
    fine. Get a motor controller for $10. and the mechanicals. You can use a
    dremel if if you want to be cheap (like drills the play in the things is
    pathetic though).
    In other words you can build your own for say... $100-300 , have it
    enclosed, quiet, and preciseand have fun doing it or you can spend $2k for
    the same thing  that  throws chips everywhere, is loud as hell and has to be
    repaired by a producer who may not exist next weak. But tell ya what toss me
    a grand ill build it for ya :P
    Why is there not a single one that I can find on google that is in the
    price range you mention ($100-$300). They are about 10 times more
    expensive, and all I wanted was to play with small double sided PCBs
    "rimus" <rasmus_pedersen@yahoo.com> wrote in message
    news:h4ehnl$29l$1@cheetah.cadsoft.de...
    possible to find.
    Anyone?
    Just to add something: I am not after the do-it-yourself kits. Only
    ready-to-use machines.
    possible to find.
    Anyone?
    How about the Elektor profiler Pro
    http://www.elektor.com/projects/profiler-pro-upgrades.957535.lynkx
    It looks nice, but the price is way out of reach I think for a few hobby
    PCBs. It looks like $2900? But thanks for the suggestion though.
    pathetic though).
    possible to find.
    Anyone?
    possible to find.
    Anyone?
    -Kenny
    possible to find.
    Anyone?
