EAGLE User Chat (English) CAM file types
  • Subscribers 181 subscribers
  • Views 1041 views
CAM file types
autodeskguest over 15 years ago
I am a bit confused by the file types created by CAM.  I am using
GERBER_RS274X_25 as recommended by my board house.  If I specify the top
copper (2 layer board) and a NAME I get two files NAME and NAME.gpi.
The board house says that Eagle should output a file NAME.cmp for this.
  All the other layers do similar.
Are there not standard file names that Eagle generates for the different
layers?
John Bachman, W1JGB
AnaTek Corporation
    Former Member over 15 years ago
    ..gpi is only a ASCII information file. Use an simple text-editor to see its
    contents. AFAIR there are examples for the files setup at the end of the
    manual.
    r
  • dukepro
    dukepro over 15 years ago
    layers?
    I've never heard of a standard file naming scheme.  But to make things
    clear, I always embed the name of the layer in the file name.
    NAME-RevA-TopScreen.gbr
    NAME-RevA-TopMask.gbr
    NAME-RevA-TopPaste.gbr
    NAME-RevA-TopCopper.gbr
    NAME-RevA-Inner1.gbr
    Of course, I'll substitute the NAME with the actual part number of the
    board.  In our house, it's usually a 6-digit number.
    That way there's no ambiguity at all as to which gerber file describes
    which layer.
    As for creating the job itself, I usually copy the .cam file from some
    other project, and do a global search-and-replace on the old name and
    revision.  Then I load it into the CAM processor and run from there.
    This seems to be a lot easier than manually editing each section from
    the GUI interface.
    I have also added a section to each CAM file that various internal shell
    scripts external to Eagle understand.  Eagle conveniently ignores these
    "extended" sections when loading the .cam file.
    Oddly enough, the .cam file has a structure similar to Winbloze's .ini
    file.  It'd be nice if they went to an XML or even a properties file
    format that could be easily read by Java.  Perhaps that's something I
    should post to the suggestion forum.
    Enjoy,
        - Chuck
    layers?
    which layer.
    the GUI interface.
    Enjoy,
         - Chuck
    Thanks for the reply.
    I dug into the manual a bit more and got even more confused.  Pages 272
    and 273 list the file names and extensions that running Gerber274x
    supposedly produces:
              %Name.cmp
              %Name.sol
              %Name.plc
              %Name.stc
              %Name.sts
    When I run it I get the file name that I entered into that block and a
    Name.gpi file and nothing more.
    John Bachman, W1JGB
    AnaTek Corporation
  • dukepro
            %Name.cmp
            %Name.sol
            %Name.plc
            %Name.stc
            %Name.sts
    I took a look at gerb274x.cam that was distributed with 5.7.0.  It
    should be producing more than just the .gpi's.  The file name extensions
    of ".cmp", ".sol", and such are left over from the pre-surface-mount
    days when all the components were put on one side of the board and
    soldered on the other.  With the advent of surface mount technology,
    components can be placed on both sides of the board rendering the
    nomenclature "component side" and "solder side" obsolete.  These are
    generally replaced with "top" and "bottom".
    Getting back to the original problem, the "%N" will expand to the name
    of the file that is currently opened.  So if the file you have opened is
    called "test.brd", you should expect files named:
        test.cmp
        test.sol
        test.plc
    and so on.
    Each section of a cam job will produce its own .gpi file.  So Section 1
    titled "Component Side" will produce  "test.cmp" and "test.gpi".
    Section 2, which is titled "Solder side" will produce "test.sol" and
    "test.gpi".  Notice that the .gpi file produced in the first section
    gets overwritten with the gpi produced in the second section.
    Therein lies the reason for doing more with the file name as described
    in a previous post.
    May I suggest trying this: copy gerb274x.cam to a new file "test.cam".
    Edit "test.cam" in your favorite plain text editor (notepad, vim, emacs,
    etc) and change the output names of each section to something like:
        %N-TopCopper.gbr
        %N-BotCopper.gbr
        %N-TopScreen.gbr
        %N-TopMask.gbr
        %N-BotMask.gbr
    Save it, load it in the cam processor, and run it.  What output do you get?
    Hope this helps.
    Enjoy,
        - Chuck
  • dukepro
    top copper (2 layer board) and a NAME I get two files NAME and NAME.gpi.
    this.  All the other layers do similar.
    different layers?
    After re-reading your original post, I think I see what's happening.
    Are you clicking on "Process Section" or on "Process Job".  The former
    will run only the section that's selected; the latter will run all sections.
    I have attached a CAM file for a 4-layer board.  Perhaps it will serve
    as an adequate example.
    Enjoy,
        - Chuck
    different layers?
    Enjoy,
         - Chuck
    OK, that helped a lot.  I think that I have it now.  Thanks very much.
    Now on to making a drill file.
    John Bachman, W1JGB
    AnaTek Corporation
