EAGLE User Support (English) Female versions of pinhead library?
  • Subscribers 189 subscribers
  • Views 7379 views
embeddedbob
embeddedbob over 12 years ago
Hopefully I've simply overlooked the obvious parts in the libraries, but are there female versions of the pinhead library?  Specifically, I'm looking for 2X15 and 2X20 90 degree connectors.  It's not hard to make new devices but figured they might already be there already.
Bob
  • embeddedbob
    embeddedbob over 12 years ago in reply to michaelwylie
    con-lsta is exactly what I was looking for, and I can add the missing 2x15.
    Michael, I considered using the male header but was concerned that someone would question why the "wrong part" (the female version) was put onto a board when the design indicated a male was supposed to be used.  It might also prevent me from making a mistake and soldering the wrong part to the wrong board.
    Thanks for the help!
    Bob
    autodeskguest over 12 years ago
    You're probably looking for the ones in "con-lsta", although a quick
    look on V5 suggests the 15x2 R/A is missing.
  • michaelwylie
    michaelwylie over 12 years ago
    I don't use Eagle, but unless you are 3d modeling wouldn't the header footprint be the same for both male and female headers?
