EAGLE User Support (English) How to have parts with tolerances and voltage ratings on the schematic?
  • Subscribers 178 subscribers
  • Views 566 views
ewoknightmares
ewoknightmares over 12 years ago
Hello, I'm new to using Eagle.  I am attempting to make my own library before I can start.
My goal is to have power ratings, tolerances, voltage ratings, etc. communicated on my schematics when it is necessary.  I used to do this in Altium and it was very helpful.  If these properties could be generated with the BOM too, that would be even better.
I see that I can add layers, and I was thinking I could make a resistor library with a tolerance layer, for example.
Is this a feasible and flexible way to do it?  I don't want to go down the wrong road and then realize I have to redo everything as I so often am used to happening with CAD programs.
  • ewoknightmares
    0 ewoknightmares over 12 years ago
    I also see that I can add attributes in schematics, PCBs, and libraries.
    The help is confusing because I am not sure which approach to take.
  • ewoknightmares
    I got it working with attributes.  Bye.
    0 Former Member over 12 years ago in reply to ewoknightmares
    I'm a new Eagle user too and I've had the same question.  Up until now I've just been creating text on the "info" layer for voltages and tolerances.  But I just tried attributes and sure enough that works well!  The attribute stays attached to the part the same way the regular name and value do with a line, and can be moved about with the move command. Good to know.
