I redefined a bus name using the information window rather that using the name tool. Now the circuit schematic won't load because of the following error:
line 8041, column 6: redefinition of name 'DIG[0..7]' in tag <bus>
How can I fix the file?
following error:
http://www.element14.com/community/message/98320
Hi
You can either:
1. open the schematic in a text editor and correct the error at line
8041. Post your schematic here, if you like, and we can have a look at
the xml. Tell us what the bus name should be and I can likely at least
make it load.
2. Revert to the last good saved version of you design. The board and
schematic pairs save as .s#1 and .b#2 in the project directory. So
change the names of a pair to .sch and .brd and try those. First name
the damaged pair something else.
I was able to rename a bus from the info box trying all combinations I
felt would trip it up, with no problem
HTH
Warren
Woopps
The pairs will have the same number
i.e. .s#1 and .b#1
.s#2 and .b#2
Warren
