    Members
    • Experts & Guidance
    • Avnet Boards Community
    • Or choose another store...
EAGLE User Support (English) eaglecon.exe -A
Autodesk EAGLE requires membership for participation - click to join
  • Subscribers 144 subscribers
  • Views 193 views
eaglecon.exe -A
Former Member over 9 years ago
"Houston, we have a problem...."
Hi everyone,
1.) I'm trying to generate the following gerbers variant of assembly from a batch file with the last version of eagle 7.1.0 and beta 7.1.1.
The eaglecon command -A return me a problem and not generate the gerbers as desidered.
The normal "total" assembly is good and also the manual generating by the eaglecad sw is ok.
Anyone can help me?
the batch commands are the following
rem ----------------------------------------------------------------------------
rem GENERAZIONE FILE GERBER VARIANTI
IF NOT (%variant_1%) == (0) (
    eaglecon.exe -A%variant_1% -X+ -N+ -dGERBER_RS274X -o%gerber_top_assembly_variant1% %brd_path% Milling tDocu
    eaglecon.exe -A%variant_1% -X+ -N+ -dGERBER_RS274X -o%gerber_bottom_assembly_variant1% %brd_path% Milling bDocu
IF NOT (%variant_2%) == (0) (
    eaglecon.exe -A%variant_2% -X+ -N+ -dGERBER_RS274X -o%gerber_top_assembly_variant2% %brd_path% Milling tDocu
    eaglecon.exe -A%variant_2% -X+ -N+ -dGERBER_RS274X -o%gerber_bottom_assembly_variant2% %brd_path% Milling bDocu
IF NOT (%variant_3%) == (0) (
    eaglecon.exe -A%variant_3% -X+ -N+ -dGERBER_RS274X -o%gerber_top_assembly_variant3% %brd_path% Milling tDocu
    eaglecon.exe -A%variant_3% -X+ -N+ -dGERBER_RS274X -o%gerber_bottom_assembly_variant3% %brd_path% Milling bDocu
The error is:
2.) I've another problem if I try to generate a gerber with the -X parameter, the eagle soft crash. To solve the problem I used the -X+ case. It's right?
An Avnet Company © 2023 Premier Farnell Limited. All Rights Reserved.
