      • Japan
      • Vietnam
Altium CircuitStudio
  • Altium CircuitStudio
Blog Ground plane fails at Circuit Studio
  • Author Author: pascale2
  • Date Created: 31 Aug 2018 2:28 PM Date Created
  • Views 76534 views
  • ground plane
pascale2
pascale2
31 Aug 2018
0down votefavorite
Hello, could you please advise on the following topic:
First time I make a ground plane in circuit studio. I really follow the tutorial.
I select the pour polygon as you see. Ok here I named the plane GND, even with a different name fails
So I select the 4 corners, right click and voila :
The pcb is full of errors and I don't see why it also ties to other nodes as well, it should be tied only to GND. Could it be that I need to change some DRC rules? But honestly I don't think so.
Yes, all my ground nodes are named as GND, no need to share the schematics.
I have a 2 layer pcb. Yes, I tried to play a bit with the settings , remove dead copper etc. Same problem. No need to say that a DRC check with this is a disaster.
Please, any substantial recommendations are welcome !
  • e14softwareuk
    e14softwareuk over 7 years ago
    Hi. You have written this as a blog post rather than posting on the forums as a question (see the Ask The Expert button) where you will most likely get far more answers.
  • e14softwareuk
