Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Circuit Studio - Net definitions seem to be corrupted how do I fix
  • Locked Locked
  • Subscribers 88 subscribers
  • Views 1244 views
richardday123
richardday123 over 5 years ago
I was busy working away, completed my schematic and then wanted to update my PCB file.
Then this problem occured, basically all my power objects (3V3, 5V0 and GND) are fine in the schematic but in the PCB all are combined and put into the 3V3 net, and I cant see how to fix.
All my ground pins are 3v3 in my PCB even though they are not defined as such in the schmatic.
I attach a dump from the Messages dialog, and then two screen shots that show the problem.
Compiler [Warning] Hardware_Architecture.SchDoc Nets Wire 3V3 has multiple names (Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object 3V3,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND,Power Object GND) 22:37:03 08/07/2021 3
An inductor has GND on Pin1, and AMP_GND on Pin 2 in the Schematic.  When you compile it and update the PCB,  Pin1 is 3V3 and Pin2 is AMP_GND.
Altium Circuit Studio completely ignores the net name and just merges everything into net 3V3.
Any ideas what I am to do, this design is a few hundred hours old and was fine until this afternoon when the pins in these nets merged themselves together into 3v3.
Regards
Richard
  • tarribred61
    tarribred61 over 5 years ago
    This might be from having a component on the schematic act as a short circuit.  Maybe it has two pins on top of each other or there is a some other way it bridges nets connected to it.  Typically an intentional connection of two different net names is done using a net tie type part.  Check if your schematic has any intentional jumper type components that are not defined properly as net ties.  Then perhaps check for schematic components that have pins that overlap.  For instance, this might happen if there are any hidden pins on the part, (which is something I never do anymore).  Or if you didn't intend to hide a pin but took a schematic symbol from elsewhere and it had a hidden pin that you missed, you might have put another visible pin on top of it.
    You might try to review the electrical rules checking on the schematic and make sure it is without errors before update to the PCB.
